7961g Ringlist.xml
As you can probably guess from the title I'm trying to change the ringing tone on this phone.   I have the Ringlist.xml file which contains this:
<CiscoIPPhoneRingList>
<Ring>
<DisplayName>Old Style</DisplayName>
<FileName>ringer1.pcm</FileName>
</Ring>
<Ring>
<DisplayName>New Style</DisplayName>
<FileName>ringer2.pcm</FileName>
</Ring>
</CiscoIPPhoneRingList>
But looking at the TFTP logs the phone never seems to request this file?
Does it need to be added to the phones SEPmacaddress.cnf.xml file and if so how?
Everyone's tags (2)
1 ACCEPTED SOLUTION
Super Bronze
Re: 7961g Ringlist.xml
The ringlist.xml is downloaded when you browse to the ring menu on the handset.
Bear in mind on CCM you might not see anything in the TFTP logs if you are on default settings, as only errors are logged. You may also need to restart the TFTP server for your uploaded file to take effect.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Super Bronze
Aaron
That did it, turns out the file also didnt have the right permissions and was names incorrectly, Ringlist.xml rather than ringlist.xml
Thanks!
3736
