Community Member
7962 & cme
hi
based on cme 4.1 compatibility matrix (http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/cme41spc.htm) the 7962 phone is supported, i used 124-11XJ IOS and cme-124-11XJ.zip cme 4.1 files, but i found 7962 is not supported when i issued load command under telephony-service mode, i only found phones like 7941,61,71,....
but i didn't find 7962
any ideas please, and why it is said in cisco cme 4.1 compatibilty matrix it's supported but it seems it's not?
should i go and upgrade to 4.2 or 4.3 then?
thanks
1 REPLY
Hall of Fame Super Gold
Re: 7962 & cme
Hi, the telephone should work also with 4.1, just configure as if it was a 7961. Official support is in CME 4.2 and onward.
Please rate if it helps!
651
