7962G not install firmware with ccme
i'm installing CCME with ios 15.0(1r)M16 and with CME version 9.1, i'm trying toconfigure a 7962 telephone, intially i've decompressed to the router the firmware for this telephone and configured the tftp server, when the telephone starts it doesn't update the firmware to my version (9.2.1), the telephone brings the version 9.3.1.3, so i thinked that the problem is the version from the phone is newer than mine version, so i've made a soft factory reset, after tis i saw the telephone doanloading the first file from the firmware but never updates, so i've installed in the CME a older version (8.3.3.S) the problem persists, and i've done a hard factory reset, and now the telephone stils with the same problem and never updates de the firmware i've the follwing files in flash:
extracting apps42.8-3-2-27.sbn (2496963 bytes)
extracting cnu42.8-3-2-27.sbn (585562 bytes)
extracting cvm42sccp.8-3-2-27.sbn (2452185 bytes)
extracting dsp42.8-3-2-27.sbn (326315 bytes)
extracting jar42sccp.8-3-2-27.sbn (443607 bytes)
extracting SCCP42.8-3-3S.loads (658 bytes)
extracting term42.default.loads (662 bytes)
extracting term62.default.loads (662 bytes)
and the follwing tftp server commands:
tftp-server flash:apps42.8-3-2-27.sbn
tftp-server flash:cnu42.8-3-2-27.sbn
tftp-server flash:cvm42sccp.8-3-2-27.sbn
tftp-server flash:dsp42.8-3-2-27.sbn
tftp-server flash:jar42sccp.8-3-2-27.sbn
tftp-server flash:SCCP42.8-3-3S.loads
tftp-server flash:term42.default.loads
tftp-server flash:term62.default.loads
in telephony service i've configured the load command like that:
load 7962 term62.default
The output of debug tftp evensts is like that:
Dec  9 22:19:51.091: TFTP: Looking for term62.default.loads
Dec  9 22:19:51.095: TFTP: Opened flash0:term62.default.loads, fd 9, size 662 for process 377
Dec  9 22:19:51.095: TFTP: Finished flash0:term62.default.loads, time 00:00:00 for process 377
Anyone have a clue about this problem and how can i install a firmware in this telephone?
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
These must be new phones with new hardware revision which do not support anything below 9.3.1, so the downgrade will not work.  This was asked here few times in the last few months, your only option is to keep the current version or install newer one.  Why would you want to go down to 8.3.3 makes no sense, remember phone firmwares are independent of CME version and you can upgrade them to whatever you choose.
HTH,
Chris
ok, the problem is, i can't find this version of firmware for CCME in Cisco site, only the version 9.2.1 and the phone doesn't install this version and has no other version.
Yes, you're right, the version 15 from hardware of the 7962 doesn't support firmware versions older than 9.3(1).
Here are the release notes:
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7900_series/firmware/9_3_1SR1/release_notes/P790_BK_R4E1E768_00_rn-9_3_1_sr1-7900-series_chapter_00.html
250
