Community Member
7965 and DHCP
Hello, friends!
After rebooting the phone 7965 does not get ip address. DHCP works 100%. Did a factory reset. But did not help.
Community Member
7965 and DHCP
Hi Ravil
1) can you check by connecting laptop to the same port for which u have connected IP Phone.
          if laptop gets Ip address then problem with the phone.
2)Try to connect different IP phone which is in use.
Community Member
Re: 7965 and DHCP
All is well!
Restarted the central switch where was DHCP. After that, no problem. What was the reason and did not understand.
Thank you!
96
