7965 bricked? 123456789*0# not working
I've looked through some of the existing discussions related to the phones being stuck whilst upgrading. I've tried the available suggestions, but I think I've truly bricked a couple of my expensive lab phones :(. Here's some details. Note: all the while, the phone in ping-able.
Any pointers/help would be appreciated. Should've got a smartnet for these!
CUCM Version
admin:show version active
Active Master Version: 8.5.1.10000-26 Unrestricted
12:00:05.838347 IP 192.168.0.196.49152 > 192.168.0.5.tftp:  29 RRQ "term65.default.loads" octet
12:00:06.630706 IP 192.168.0.196.49153 > 192.168.0.5.tftp:  29 RRQ "term65.default.loads" octet
12:08:52.239712 IP 192.168.0.196.49152 > 192.168.0.5.tftp:  29 RRQ "term65.default.loads" octet
12:08:53.346161 IP 192.168.0.196.49153 > 192.168.0.5.tftp:  29 RRQ "term65.default.loads" octet
12:11:23.255617 IP 192.168.0.196.49152 > 192.168.0.5.tftp:  29 RRQ "term65.default.loads" octet
12:11:24.002638 IP 192.168.0.196.49153 > 192.168.0.5.tftp:  29 RRQ "term65.default.loads" octet
12:13:53.120572 IP 192.168.0.196.49152 > 192.168.0.5.tftp:  29 RRQ "term65.default.loads" octet
12:13:53.910372 IP 192.168.0.196.49153 > 192.168.0.5.tftp:  29 RRQ "term65.default.loads" octet
Before 12:13 <--- I used the 123456789*0# key combo
12:13 <--- I used the 3491672850*# key combo here. Same result
File does exist
admin:file list tftp term65*
dir count = 0, file count = 1
DHCP is fine (scope on CUCM, giving out correct tftp details)
admin:file tail activelog syslog/messages
Jun 15 11:18:42 CUCM85 daemon 6 dhcpd: DHCPREQUEST for 192.168.0.196 from 00:21:d8:ba:f4:d9 (SEP0021D8BAF4D9) via eth0
Jun 15 11:18:42 CUCM85 daemon 6 dhcpd: DHCPACK on 192.168.0.196 to 00:21:d8:ba:f4:d9 (SEP0021D8BAF4D9) via eth0
Everyone's tags (2)
1 ACCEPTED SOLUTION
VIP Super Bronze
Most times issues like this is caused by the wrong term65.default.loads. This file  is different for each phone firmware even though the filename is the same. There is no way you will know which term65.default.loads the server is requesting..So the safe thing to do is this..
What firmware is the phone on, what firmware is on the cucm server the phone is trying to register to. If your cucm server is runing 9.X and your phone is on firmware less than 8.5 then it wont work. You need to first of all upgrade to 8.5 before going to 9.X.
So I suggest you install firmware 8.5 on your server first, then see what happens
Please rate useful posts
"For the love of God is broader than the measure of man's mind And the heart of the Eternal is most wonderfully kind"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
VIP Super Bronze
Thanks aokanlawon!
I finally managed to get the phones back to life with the oldest SCCP firmware available (8.3.2) , using TFTD32 with its built-in dhcp server.
Re: 7965 bricked? 123456789*0# not working
thanks for sharing.....
6578
