Community Member
7965 Custom Features
Greetings;
A couple of question on customizing the programming on 7965 phone:
1) Is there anyway to customize content displayed when the help button is pressed?
2) Can the mute button be disabled?
3) Can a "check-in" button be programmed. i.e. a button would flash between 6 and 10 everyday and once pressed it would stop flashing and notification would be send to the server
Re: 7965 Custom Features
1) yes, under enterprise parameter you set the help URL, write a custom script to show whatever you want
2) no
3) This is all you can configure:
Programmable Line Keys
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/6_1_1/ccmsys/a08ipph.html#wp1129228
But any of the above provides a blinking and then just sends something. Use EM if you need them to log in to make calls.
java
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
Great - thanks. Regarding the check in feature can this be a custom service? If so can you point me in the right direction to get more info?
273
