Silver
7965 Phones don't show up on CM5.1
Hello Folks,
The 7965 phones don't show up on my CM5.1. I have installed the latest ES (cisco-ipt-k9-patch-es5.1.2.3104-1.tar.gz.sgn)for the CM5.1 and also installed "cmterm-7945_7965-sccp.8-3-3.cop.sgn" as the load to support 7965 phones. I have rebooted the server after the upgrade to the new ES and also restarted the TFTP service after installing the load. I still don't see the 7965 profile in the Device Default Configuration page. Could someone please let me know if I am missing something. Please note that the ES and the load have only been installed in the Publisher.
MK
Re: 7965 Phones don't show up on CM5.1
Verify you meet the minimum requirements using this link:
Cisco Unified IP Phone 7975G, 7965G, 7945G Release Notes for Firmware Release 8.3(2) (SCCP and SIP)
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7975g/firmware/8_3_2/english/release/notes/75832.html
maybe the version or the devpack are not the right ones
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Silver
Thanks Javalenc,
I am not able to find cmterm-devicepack5.1.2.3101-3 on the cisco.com, software downlaod page. Could you please point me to the downlaod page for the above device pack?
there are some later devpacks that also do the trick here:
http://www.cisco.com/cgi-bin/tablebuild.pl/callmgr-51
javalenc
java
Silver
Thanks Javalenc, it worked. You deserve more than 5 points.
Thanks again,
MK
125
