7965 stuck after factory reset
After doing a factory reset to the phone (i have 4 phones Behaves in the same way) the phone doing this staps :
1: shows Upgrade but stuck on it.
2:after 10 sec the phone boot an show upgrate term65.defualt but don't continue with the checkbox.
3:after 4 sec change to upgrade an stuck there .
4: after 1 min start all over  an never comes up .
My network works perfect an i can connect  any phone Including 7965 that i want but this problem that i described hapen whan i do a factory reset .
I check in the cucm if the file  the term65.defalt.load is there an it wes there .
I done a rest to the tftp service -no help.
I check the network i know that the phone get ip add from the dhcp an see the ftfp .
cucm ver 8.6
can some one can give my a new direction to solved this issu ?
thanks sharon .
Sharon,
I agree with Paolo. There so many threads...Some that  I answered myself. If you searched the forum you will find answers..
https://supportforums.cisco.com/message/3712835#3712835
https://supportforums.cisco.com/message/3661272#3661272
https://supportforums.cisco.com/message/3715072#3715072
https://supportforums.cisco.com/message/3692756#3692756
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
6 Replies 6
paolo bevilacqua
There are many threads about this, please use search function.
Hi  saw that but no helpul to my case
Hi Sharon.
Which IP Phone firmware version is present on your cucm?
I can suggest you to download and install on CUCM the latest firmware for 7945 from
http://software.cisco.com/download/release.html?mdfid=281346594&flowid=5267&softwareid=282074289&release=9.3(1)SR2&relind=AVAILABLE&rellifecycle=&reltype=latest
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Sharon,
Thanks for all i will serach with the option on my hand .
Sharon .
Sent from Cisco Technical Support Android App
The issu solved .
I downlod from cisco web the zip frimware for the 7965 device .
In the zip there a
cmterm65.defualt . I upload it to the tftp server (reset service) and it fix the cmterm .
