7970 color scheme w new FW
dannymeyer
Hi.
What do you think about the new color scheme with introduction of FW 8.4.1?
On the 7970, the appearance is very bleak and besides the little improvements reg. the windowing, I miss the old colors.
Is there a way to change them, anyway?
Danny
6 Replies 6
Steffen.Baier
we upgraded last weekend to the latest 8.4.1SR1 and since then have only got complaints from our users onsite.
We have around 3000x 7970's and I have even opened a seperate post. The new "white" is just to bright to be seen from certain angels and we just can't tell every user that they have to play with the screen angle etc to get it right.
Also the Headset ports behaves differently and the users complain about this too.
Steffen
Sfeffen.
What do you intend to do?
Are you going back to the old FW to avoid?
Would it make sense to contact product management reg. this? Maybe there is a reason, why they changed it?
Danny
adorsett
It's horrible! All of the colors seem washed out no matter what I set the angle and brightness values to. Luckily I only upgraded one test phone. I'm switching back to 8-3-4SR1.
Andrew
Steffen.Baier
Cisco's answer so far is that it is only cosmetic but if enough engineers like us explain to them that it is unacceptable then thye may change it.
I am awaiting the 8.4.1ES9 at present as that is supposed to fix the DTMF issues we have.
Steffen
Steffen.
Good point. I will open a TAC, hopefully that helps to get them feedback heard. Have also raised that with Cisco internally, but twice is better.
Danny
8.4.1ES9 still has DTMF issues as we can "hear" a scraching noise.
Will supply Cisco with a recording of it but we may have to upgrade our IOS on the Gateways as it's never been updated and that could interfere.
Steffen
