7970 phone issue with CCM 5.1
brandoncheah
Our users have noticed that following a directory lookup and call placement, users with 7970 phones have to back out of the directory as opposed to going back to the default screen.
Is there any setting in CCM or the phone to default back to the main screen?
Rob Huffman
Hi Brandon,
One more here :) Have a look at the Related Bug Details;
CSCsk38449 Bug Details
7961 (firmware 8.3.2 ) - Corporate Directory screen stays after Dial
Symptom:
In the Corporate Directory, after selecting Dial for one of the Contacts, and
finishing the call, the Corporate Directory with the contact info screen
stays on the phone. In previous version of phone load the behaviour was
different, after Dialling the contact the idle phone screen was returned.
Conditions:
CCM version 4.1(3)sr4d
cmterm-7941_7961-sccp.8-3-2
Workaround:
Selecting Cancel softkey to return to idle phone screen
1st Found-In
8.3(2)
Fixed-In
8.3(3.1)
8.4(0.25)
8.3(3)ES1
Related Bug Information after call finishes ip phone display stays on the corp dir menu
Symptom: After making a call through the corporate directory, the phone display does not return to the "On-Hook" display but is stuck on the corporate directory and so you have to manually exit Conditions: Latest firmware for 7940's, 7960's and 7970's Workaround: User can just press the "Exit" softkey twice to return to the "On-Hook" screen Further Problem Description: N/A
Hope this helps!
Rob
Rob Huffman
Hi Brandon,
Symptom:
Conditions:
Workaround:
1st Found-In
8.3(2)
Fixed-In
8.3(3.1)
8.4(0.25)
8.3(3)ES1
Hope this helps!
Rob
Thanks again Rob...I found the sccp v.8.3.5 firmware update, which file do i load? the .cop or the .cop.sgn?
Thanks.
Rob,
Thank you very much, this solved my issue with the latest firmware load.
Rob Huffman
Hi Brandon,
Nice work my friend! Sorry I missed your second post.
Take care,
Rob
