7970 unable to complete firmware load after factory reset
i have one 7970 that seems unable to load firmware after a factory reset
i belive it fails here:
Unexpected Opcode[5] Expecting ACK Block[4098], Socket[18] FileName[apps70.8-3-3ES2.sbn], th_block [0] Abort.
relavant info from tftp log
14:33:52.674 TFTP|NetworkService::asyncTFTPReadReq[0xb4592708:0:10.180.198.74:1025], Transfer completed. File[term70.default.loads] Socket[18]|<CLID::StandAloneCluster><NID::ccm05><LVL::Significant><MASK::0004>
14:34:02.683 TFTP|<--CTftpConnect::ThreadPoolProxyRun[0xb45bb880],[0xb45bb880:3:10.180.198.74:1028 |<CLID::StandAloneCluster><NID::ccm05><LVL::Entry_exit><MASK::0004>
14:34:06.654 TFTP|NetworkService::asyncTFTPReadReq[0xb45bb880:3:10.180.198.74:1028], Unexpected Opcode[5] Expecting ACK Block[4098], Socket[18] FileName[apps70.8-3-3ES2.sbn], th_block [0] Abort...|<CLID::StandAloneCluster><NID::ccm05><LVL::Error><MASK::0004>
14:34:06.654 TFTP|NetworkService::cleanupThread(17fb9bb0), fd[18], mTftpConnect[0xb45bb880], grpId[2], asyncSocket[0xb4509ae0]|<CLID::StandAloneCluster><NID::ccm05><LVL::Significant><MASK::0004>
after this it reloads , tries again
can it be fixed ?
if so , can anyone suggest software versions it might like , i have tried several....
regards
Björgvin
Hall of Fame Super Gold
Re: 7970 unable to complete firmware load after factory reset
Which FW was the phone running previously ? Might be an issue with bootloader and you need to progress with ver old releases, as old as 5.x perhaps. Also you can try the alternate reset:
3491672850*#
thank you for your reply,
it was running software from 4x before,
i changed the ccm to vers 6x
the reason i reset it was because the phone booted to a Cisco logo screen , and i little check box appeared on the botton left above softkey 1 , (first checkbox with a X and then it turned into a "check mark" ) , then it halted , just stayed that way until i would unplug it
however at that time i was using cp-pwr-inj-v02 (i am not sure it supports 7960)
now i am using POE.
do you think the bootloader can not handle the 6x firmware ?
can you tell me the difference between the resets ( i belive i tried that alternate at some point)
regards
Björgvin
349
