7970 'Unprovisioned' after convert to SIP
I have UC540 and trying to get 7970 phone to work via SIP.
SIP trunk is registered...  I've included snippet of configs.  The phone upgraded SIP firmware with no problems but once it's booted up it continues to go from 'Updating Locale' to 'Unprovisioned' and keeps cycling through that.  Any suggestions would be greatly appreciated as I'm stuck.
Line                             peer       expires(sec) registered P-Associ-URI
315120284                        -1         1956         yes
JPRA_UC540#
voice register global
mode cme
source-address 10.1.1.1 port 5060
max-dn 2
max-pool 2
load 7970 SIP70.9-2-3S
authenticate register
time-format 24
date-format D/M/Y
tftp-path flash:
create profile sync 0091671004833429
ntp-server 10.1.10.2 mode directedbroadcast
voice register dn  1
number 11
voice register template  1
dialplan 1
no conference enable
voice register pool  1
id mac 0016.C79D.6F30
type 7970
number 1 dn 1
template 1
dtmf-relay sip-notify
username sipuser1 password 123456
description SIP User 1
codec g711ulaw
Everyone's tags (4)
Hall of Fame Super Gold
Why SIP? You loose feature, but gain bugs and limitations in doing so.
Hello guys. I have the same
Hello guys. I have the same problem with my Cisco 7970G IP phone which I'm trying to configure to work via SIP. Below is the part of my config:
tftp-server flash:/7970/SIP/apps70.9-4-2ES9.sbn alias apps70.9-4-2ES9.sbn
tftp-server flash:/7970/SIP/cnu70.9-4-2ES9.sbn alias cnu70.9-4-2ES9.sbn
tftp-server flash:/7970/SIP/cvm70sip.9-4-2ES9.sbn alias cvm70sip.9-4-2ES9.sbn
tftp-server flash:/7970/SIP/dsp70.9-4-2ES9.sbn alias dsp70.9-4-2ES9.sbn
tftp-server flash:/7970/SIP/jar70sip.9-4-2ES9.sbn alias jar70sip.9-4-2ES9.sbn
tftp-server flash:/7970/SIP/SIP70.9-4-2SR1-1S.loads alias SIP70.9-4-2SR1-1S.loads
tftp-server flash:/7970/SIP/term70.default.loads alias term70.default.loads
tftp-server flash:/7970/SIP/term71.default.loads alias term71.default.loads
voice service voip
 allow-connections sip to sip
 fax protocol cisco
 sip
  registrar server
 mode cme
 source-address 177.3.11.1 port 5060
 max-dn 10
 max-pool 5
 load 7970 SIP70.9-4-2SR1-1s
 tftp-path flash:
 create profile sync 0078327219347302
voice register dn  1
 number 3002
 id mac 001F.9E26.4B8B
 number 1 dn 1
 codec g711ulaw
The 1st problem is that phone is stuck with UNPROVISIONED error.
The 2nd problem is that after erasing config section for SIP and entering lines for SCCP aliases I get the error (on screenshots).
Could you please help me to solve this problem.
1218
