7970 will not register in CME 8.6
My 7960' work fine but I cannot get my 7970 to rgister in CME 8.6.
The firmware version on the phone is SCCP70.9-2-1SR2S and below is my config settings in CME/
tftp-server flash:P00308000800.sbn
tftp-server flash:P00308000800.loads
tftp-server flash:P00308000800.txt
tftp-server flash:P00308000800.sb2
tftp-server flash:SEP0013191f4980.cnf.xml
tftp-server flash:Phone/7970/SCCP70.9-1-1SR1S.loads alias SCCP70.9-1-1SR1S.loads
tftp-server flash:Phone/7970/jar70sccp.9-1-1TH1-16.sbn alias jar70sccp.9-1-1TH1-16.sbn
tftp-server flash:Phone/7970/dsp70.9-1-1TH1-16.sbn alias dsp70.9-1-1TH1-16.sbn
tftp-server flash:Phone/7970/cvm70sccp.9-1-1TH1-16.sbn alias cvm70sccp.9-1-1TH1-16.sbn
tftp-server flash:Phone/7970/apps70.9-1-1TH1-16.sbn alias apps70.9-1-1TH1-16.sbn
tftp-server flash:Phone/7970/cnu70.9-1-1TH1-16.sbn alias cnu70.9-1-1TH1-16.sbn
tftp-server flash:Phone/7970/term71.default.loads alias term71.default.loads
tftp-server flash:Phone/7970/term70.default.loads alias term70.default.loads
load 7960-7940 P00308000800
load 7970 SCCP70.9-1-1SR1S
ephone  3
device-security-mode none
mac-address 0018.1994.565F
speed-dial 6 6000 label "PSTN"
type 7970
button  1:1 2f2
sh ephone result:
ephone-3[2] Mac:0018.1994.565F TCP socket:[-1] activeLine:0 whisperLine:0 UNREGISTERED
mediaActive:0 whisper_mediaActive:0 startMedia:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:0
IP:10.110.0.49 * 49862 Unknown 0  keepalive 0 max_line 0 available_line 0
button 1: cw:1 ccw:(0 0)
  dn 1  number 1000 CH1   IDLE         CH2   IDLE
button 2: cw:1 ccw:(0 0)
  dn 2  number 1001 CH1   IDLE         CH2   IDLE         mwi feature-ring
speed dial 6:6000 PSTN
Preferred Codec: g711ulaw
Lpcor Type: none
can you fine the below , please?.
Telephony-service
create cnf-files
Thank you
please rate all useful information
That did not fix the probkem.
Re: 7970 will not register in CME 8.6
can you please share with me "debug tftp events"?. Please also share configurtaion under telephony-service.The last thing make factory reset.Check also if the IP phone 7970 can get an IP address , if you use DHCP try to put the IP address as static.
Thank you
THe IP address on the phone is 10.110.0.176/24, router 10.110.0.1 DHCP 172.16.2.1, TFTP 10.110.0.1; all is correct.
Show Telephony-service
CONFIG (Version=8.6)
Version 8.6
Max phoneload sccp version 17
Max dspfarm sccp version 18
Cisco Unified Communications Manager Express
For on-line documentation please see:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/tsd_products_support_series_home.html
protocol mode default
ip source-address 10.110.0.1 port 2000
ip qos dscp:
ef (the MS 6 bits, 46, in ToS, 0xB8) for media
cs3 (the MS 6 bits, 24, in ToS, 0x60) for signal
af41 (the MS 6 bits, 34, in ToS, 0x88) for video
default (the MS 6 bits, 0, in ToS, 0x0) for serviceservice directed-pickup
no auto-reg-ephone
max-ephones 100
max-dn 20
max-conferences 4 gain -6
dspfarm units 0
dspfarm transcode sessions 0
conference software
privacy
no privacy-on-hold
hunt-group report delay 1 hours
hunt-group logout DND
max-redirect 10
voicemail 5000
cnf-file location: system:
cnf-file option: PER-PHONE-TYPE
network-locale[0] US   (This is the default network locale for this box)
network-locale[1] US
network-locale[2] US
network-locale[3] US
network-locale[4] US
user-locale[0] US    (This is the default user locale for this box)
user-locale[1] US
user-locale[2] US
user-locale[3] US
user-locale[4] US
srst mode auto-provision is OFF
srst ephone template is 0
srst dn template is 0
srst dn line-mode single
moh MoH.wav
time-format 12
date-format mm-dd-yy
timezone 12 Eastern Standard/Daylight Time
url services http://singlewire.com/freeservices/menu
no transfer-pattern is configured, transfer is restricted to local SCCP phones only.
keepalive 30 auxiliary 30
timeout interdigit 10
timeout busy 10
timeout ringing 180
timeout transfer-recall 0
timeout ringin-callerid 8
timeout night-service-bell 12
caller-id name-only: enable
system message The Durham Corporation
web admin system name Admin
web admin customer name Customer
edit DN through Web:  disabled.
edit TIME through web:  disabled.
background save interval 10 minutes
Log (table parameters):
     max-size: 150
     retain-timer: 15
create cnf-files version-stamp 7960 Oct 20 2013 17:23:26
transfer-system full-consult
transfer-digit-collect new-call
multicast moh 239.2.2.2 port 2000
local directory service: enabled.
Extension-assigner tag-type ephone-tag.
Debug tftp event
026477: 5d03h: TFTP: Looking for CTLSEP00181994565F.tlv
026478: 5d03h: TFTP: Looking for ITLSEP00181994565F.tlv
026479: 5d03h: TFTP: Looking for ITLFile.tlv
026480: 5d03h: TFTP: Looking for SEP00181994565F.cnf.xml.sgn
026481: 5d03h: TFTP: Looking for XMLDefault.cnf.xml.sgn
CME_Router#
026482: 5d03h: TFTP: Looking for CTLSEP00181994565F.tlv
026483: 5d03h: TFTP: Looking for ITLSEP00181994565F.tlv
026484: 5d03h: TFTP: Looking for ITLFile.tlv
026485: 5d03h: TFTP: Looking for SEP00181994565F.cnf.xml.sgn
CME_Router#
026486: 5d03h: TFTP: Looking for XMLDefault.cnf.xml.sgn
show telephony-service tftp-binding
tftp-server system:/its/united_states/7960-tones.xml alias United_States/7960-tones.xml
tftp-server system:/its/united_states/7960-font.xml alias English_United_States/7960-font.xml
tftp-server system:/its/united_states/7960-font.xml alias English_United_States/7920-font.xml
tftp-server system:/its/united_states/7960-dictionary.xml alias English_United_States/7960-dictionary.xml
tftp-server system:/its/united_states/7960-kate.xml alias English_United_States/7960-kate.xml
tftp-server system:/its/united_states/7960-kate.xml alias English_United_States/7920-kate.xml
tftp-server system:/its/united_states/SCCP-dictionary.xml alias English_United_States/SCCP-dictionary.xml
tftp-server system:/its/vrf1/XMLDefault7940.cnf.xml alias SEP0017E032E994.cnf.xml
tftp-server system:/its/vrf1/XMLDefault7970.cnf.xml alias SEP00181994565F.cnf.xml
tftp-server system:/its/SEPDEFAULT.cnf alias SEPDefault.cnf
tftp-server system:/its/vrf1/XMLDefault.cnf.xml alias XMLDefault.cnf.xml
tftp-server system:/its/vrf1/ATADefault.cnf.xml alias ATADefault.cnf.xml
I fixed it.  II unlocked the phone, **# then pressed the ERASE key.  The phone rebooted and loaded the firmware from my tftp server to SCCP70.9-1-1SR1S form SCCP70.9-1-1SR2S and the phone now works.  Thanks for your help.
684
