Community Member
7970G Firmware upgrade question - CME 3.4
OK, I have been experiencing time problems and a couple of other little issues on my 7970G's, which have been pretty much untouched since we installed CME. As a result of that as well as a notification I recieved from my Cisco vendor about patches for upcoming summer-time changes in the US, I have been looking to upgrade the firmware on the 7970G phones.
When I do a sh telephony-service all, I get this:
CONFIG [Version=3.4(0)]
Version 3.4(0)
Cisco CallManager Express
For on-line documentation please see:
ip source-address port 2000
load 7960-7940 P00307020200
max-ephones 48
max-dn 192
max-conferences 8 gain -6
dspfarm units 0
dspfarm transcode sessions 0
hunt-group report delay 1 hours
max-redirect 5
voicemail 500
time-format 12
date-format mm-dd-yy
timezone 5 Pacific Standard/Daylight Time
transfer-pattern 9.......
after-hours block pattern 1 919......... 7-24
keepalive 30
timeout interdigit 10
timeout busy 10
timeout ringing 180
caller-id name-only: enable
system message *
web admin system name * password *
web admin customer name *
edit DN through Web: enabled.
edit TIME through web: enabled.
Log (table parameters):
max-size: 150
retain-timer: 15
create cnf-files version-stamp 7960 Aug 22 2006 09:54:58
transfer-system full-consult
auto assign 1 to 1
local directory service: enabled.
There is no load shown for the 7970 phones.. is this correct? The 7970s have been working fine (aside from the time sync problems) since we started using them in March of 2006. Should there be anything listed for them?
Also, I am a little unclear on what firmware I should be using. We are using SCCP. The firmware I can find available for download on Cisco's website only lists CallManager versions for compatibility -- not CME. Are there different files for CME?
Currently the 7970s are running these software versions:
Load File = TERM70.DEFAULT
App Load ID = Jar70.2-9-1-45.sbn
JVM Load ID = CVM70 2-0-1-45.sbn
OS Load ID = cnu70.2-7-5-50.sbn
Boot Load ID = 7970_64060118.bin
Hall of Fame Super Gold
Re: 7970G Firmware upgrade question - CME 3.4
Hi Chris,
unless you configure load, nothing will appear in config or "show telephony-service".
If you are happy with all the 7970 does, do not upgrade. The latest 7.x version is 7.0.3
The files for CME are packaged as ZIP on CCO download, but the same images are used for CME and CCM.
Community Member
Thanks for the tip on the .ZIP firmware images.
So, it isn't wrong that there is no load configured for the 7970G in the telephony-config?
Without configuring load the phones will just keep the firmware they are booted with. Nothing is wrong with that.
