11-09-2008 07:06 PM - edited 03-15-2019 02:25 PM
When I add 2nd lines at the call manager and press reset phone at call manager, phone got hangs, and no response at all. And I have to unplug and replug in the lan cable to take effect, and the phone works normal then.
Call Manager: 4.2(3)sr2b
OS: Win Sever 2000
Phone: 7970G with "SCCP70.8-3-3SR2S"
Please kindly advice what else I have to look at to solve this issue. Thank so much!
11-09-2008 09:51 PM
Can you give us more details, for the hang?
Did the phone reset or not?
What you see in the screen?
Only adding 2 lines?
With one line all works fine?
Please give us more details
11-09-2008 10:17 PM
1. No the phone actaully cannot be reset when adding 2nd lines, and it was only displayed "reset" and keep hanging (or no response) after I click 'reset' at the call manager.
2. The screen only see "reset" / "resetting", and hang it right there. (that needs to unplug and replug in the lan cable to take effect of the change )
3. Yes, issue shows up when 2nd lines added
4. Yes, one line works fine
Thanks and let me know if you need more detail.
11-11-2008 08:06 PM
