7975 Background Image
I have a background images that works perfectly fine on both 7911 and 7970. However, whatever i tried it doesn't appear on the list on the 7975.
Would appreciated if anyone can shed some light on this.
Cheers,
Hunt
1 REPLY
Re: 7975 Background Image
size is not the same, make sure to put it on right folder and adjust image
7975
Full size image-320 pixels (width) X 216 pixels (height).
Thumbnail image-80 pixels (width) X 53 pixels (height).
Directory "/Desktops/320x216x16"
java
if this helps, please rate
java
www.cisco.com/go/pdi
441
