Community Member
7975 configuration
i already googled this like a champ, but i still have a few problems with my 7975 setup:
1. - time on the phone is'n right. i used ntp.sipgate.net as the ntp-server in the MAC.cnf.xml, but it doesn't work. with my old 7960 it worked fine.
2. - When i have an incoming call the display keeps black and doesn't turn on. I know that it can be changed but how?
3. - I can't change the ringtones. The files an the ringlist.xml are in the TFTP root, but the phone doesn't even try to load it.
Can anyone help me please?
This is my MAC.cnf.xml:
<?xml version="1.0" encoding="UTF-8"?> <device>   <deviceProtocol>SIP</deviceProtocol>   <sshUserId>admin</sshUserId>   <sshPassword>admin</sshPassword>   <devicePool>                 <dateTimeSetting>                         <dateTemplate>D.M.YY</dateTemplate>                         <timeZone>Central Europe Standard/Daylight Time</timeZone>                         <ntps>                                 <ntp>                                         <name>ntp.sipgate.net</name>                                         <ntpMode>Unicast</ntpMode>                                 </ntp>                         </ntps>                 </dateTimeSetting>      <callManagerGroup>         <members>            <member priority="0">               <callManager>                  <ports>                     <ethernetPhonePort>2000</ethernetPhonePort>                     <sipPort>5060</sipPort>                     <securedSipPort>5061</securedSipPort>                  </ports>                  <processNodeName>192.168.1.1</processNodeName>               </callManager>            </member>         </members>      </callManagerGroup>   </devicePool>   <commonProfile>      <phonePassword></phonePassword>      <backgroundImageAccess>true</backgroundImageAccess>      <callLogBlfEnabled>2</callLogBlfEnabled>   </commonProfile>   <loadInformation>SIP75.8-5-3S</loadInformation>   <vendorConfig>      <disableSpeaker>false</disableSpeaker>      <disableSpeakerAndHeadset>false</disableSpeakerAndHeadset>      <pcPort>0</pcPort>      <settingsAccess>1</settingsAccess>      <garp>0</garp>      <voiceVlanAccess>0</voiceVlanAccess>      <videoCapability>0</videoCapability>      <autoSelectLineEnable>0</autoSelectLineEnable>      <sshAccess>0</sshAccess>      <sshPort>22</sshPort>      <webAccess>0</webAccess>      <spanToPCPort>1</spanToPCPort>      <loggingDisplay>1</loggingDisplay>      <loadServer></loadServer>      <daysDisplayNotActive></daysDisplayNotActive>      <displayOnTime>00:00</displayOnTime>      <displayOnDuration>00:00</displayOnDuration>      <displayIdleTimeout>00:03</displayIdleTimeout>   </vendorConfig>   <deviceSecurityMode>1</deviceSecurityMode>   <authenticationURL>http://192.168.44.1/ciscoauth.php</authenticationURL>   <directoryURL>http://192.168.44.1/telBOOK.php</directoryURL>   <idleURL></idleURL>   <informationURL></informationURL>   <messagesURL></messagesURL>   <proxyServerURL></proxyServerURL>   <servicesURL></servicesURL>   <dscpForSCCPPhoneConfig>96</dscpForSCCPPhoneConfig>   <dscpForSCCPPhoneServices>0</dscpForSCCPPhoneServices>   <dscpForCm2Dvce>96</dscpForCm2Dvce>   <transportLayerProtocol>2</transportLayerProtocol>   <capfAuthMode>0</capfAuthMode>   <capfList>      <capf>         <phonePort>3804</phonePort>      </capf>   </capfList>   <certHash></certHash>   <encrConfig>false</encrConfig>    <sipProfile>      <sipProxies>         <backupProxy></backupProxy>         <backupProxyPort></backupProxyPort>         <emergencyProxy></emergencyProxy>         <emergencyProxyPort></emergencyProxyPort>         <outboundProxy></outboundProxy>         <outboundProxyPort></outboundProxyPort>         <registerWithProxy>true</registerWithProxy>      </sipProxies>      <sipCallFeatures>         <cnfJoinEnabled>true</cnfJoinEnabled>         <callForwardURI>x--serviceuri-cfwdall</callForwardURI>         <callPickupURI>x-cisco-serviceuri-pickup</callPickupURI>         <callPickupListURI>x-cisco-serviceuri-opickup</callPickupListURI>         <callPickupGroupURI>x-cisco-serviceuri-gpickup</callPickupGroupURI>         <meetMeServiceURI>x-cisco-serviceuri-meetme</meetMeServiceURI>         <abbreviatedDialURI>x-cisco-serviceuri-abbrdial</abbreviatedDialURI>         <rfc2543Hold>false</rfc2543Hold>         <callHoldRingback>2</callHoldRingback>         <localCfwdEnable>true</localCfwdEnable>         <semiAttendedTransfer>true</semiAttendedTransfer>         <anonymousCallBlock>2</anonymousCallBlock>         <callerIdBlocking>2</callerIdBlocking>         <dndControl>0</dndControl>         <remoteCcEnable>true</remoteCcEnable>      </sipCallFeatures>      <sipStack>         <sipInviteRetx>6</sipInviteRetx>         <sipRetx>10</sipRetx>         <timerInviteExpires>180</timerInviteExpires>         <timerRegisterExpires>3600</timerRegisterExpires>         <timerRegisterDelta>5</timerRegisterDelta>         <timerKeepAliveExpires>120</timerKeepAliveExpires>         <timerSubscribeExpires>120</timerSubscribeExpires>         <timerSubscribeDelta>5</timerSubscribeDelta>         <timerT1>500</timerT1>         <timerT2>4000</timerT2>         <maxRedirects>70</maxRedirects>         <remotePartyID>false</remotePartyID>         <userInfo>None</userInfo>      </sipStack>      <autoAnswerTimer>1</autoAnswerTimer>      <autoAnswerAltBehavior>false</autoAnswerAltBehavior>      <autoAnswerOverride>true</autoAnswerOverride>      <transferOnhookEnabled>false</transferOnhookEnabled>      <enableVad>false</enableVad>      <preferredCodec>none</preferredCodec>      <dtmfAvtPayload>101</dtmfAvtPayload>      <dtmfDbLevel>3</dtmfDbLevel>      <dtmfOutofBand>avt</dtmfOutofBand>      <alwaysUsePrimeLine>false</alwaysUsePrimeLine>      <alwaysUsePrimeLineVoiceMail>false</alwaysUsePrimeLineVoiceMail>      <kpml>3</kpml>      <natEnabled>false</natEnabled>      <natAddress></natAddress>      <stutterMsgWaiting>0</stutterMsgWaiting>      <callStats>false</callStats>      <silentPeriodBetweenCallWaitingBursts>10</silentPeriodBetweenCallWaitingBursts>      <disableLocalSpeedDialConfig>false</disableLocalSpeedDialConfig>      <startMediaPort>16384</startMediaPort>      <stopMediaPort>32766</stopMediaPort>      <voipControlPort>5060</voipControlPort>      <dscpForAudio>184</dscpForAudio>      <ringSettingBusyStationPolicy>0</ringSettingBusyStationPolicy>      <dialTemplate>dialplan.xml</dialTemplate>      <phoneLabel>Olli</phoneLabel>      <sipLines>         <line button="1">            <featureID>9</featureID>            <featureLabel>sip.1und1</featureLabel>                    <name>620</name>                    <displayName>sip.1und1</displayName>                    <contact>620</contact>            <proxy>USECALLMANAGER</proxy>            <port>5060</port>            <autoAnswer>               <autoAnswerEnabled>2</autoAnswerEnabled>            </autoAnswer>            <callWaiting>3</callWaiting>            <authName>620</authName>            <authPassword>cisco</authPassword>            <sharedLine>false</sharedLine>            <messageWaitingLampPolicy>1</messageWaitingLampPolicy>            <messagesNumber>*97</messagesNumber>            <ringSettingIdle>4</ringSettingIdle>            <ringSettingActive>5</ringSettingActive>            <forwardCallInfoDisplay>               <callerName>true</callerName>               <callerNumber>true</callerNumber>               <redirectedNumber>false</redirectedNumber>               <dialedNumber>true</dialedNumber>            </forwardCallInfoDisplay>         </line>         <line button="2">            <featureID>2</featureID>            <featureLabel>Papa Home</featureLabel>            <speedDialNumber>12345</speedDialNumber>         </line>         <line button="3">            <featureID>2</featureID>            <featureLabel>Papa Handy</featureLabel>            <speedDialNumber>12345</speedDialNumber>         </line>             <line button="4">            <featureID>2</featureID>            <featureLabel>Mopsi Home</featureLabel>            <speedDialNumber>12345</speedDialNumber>         </line>             <line button="5">            <featureID>2</featureID>            <featureLabel>Mopsi Handy</featureLabel>            <speedDialNumber>12345</speedDialNumber>         </line>           <line button="6">            <featureID>2</featureID>            <featureLabel>Oma + Opa</featureLabel>            <speedDialNumber>12345</speedDialNumber>         </line>             <line button="7">            <featureID>2</featureID>            <featureLabel>Saats Pizza</featureLabel>            <speedDialNumber>12345</speedDialNumber>         </line>         <line button="8">            <featureID>2</featureID>            <featureLabel>Shell</featureLabel>            <speedDialNumber>12345</speedDialNumber>         </line>                     </sipLines>   </sipProfile> </device>
Everyone's tags (3)
1 REPLY
Community Member
7975 configuration
  SIP
  admin
  admin
                        D.M.YY
                                        ntp.sipgate.net
                                        Unicast
                    2000
                    5060
                    5061
                 192.168.1.1
     true
  SIP75.8-5-3S
     false
     false
     00:00
     00:03
  96
  false
        true
        true
        false
        true
        true
        true
        6
        3600
        120
        4000
        70
        false
        None
     false
     true
     false
     false
     none
     101
     avt
     false
     false
     false
     false
     false
     16384
     32766
     5060
     184
     dialplan.xml
     Olli
           9
           sip.1und1
                   620
                   sip.1und1
                   620
           USECALLMANAGER
           5060
           cisco
           false
           *97
              true
              true
              false
              true
           Papa Home
           12345
           Papa Handy
           12345
           Mopsi Home
           12345
           Mopsi Handy
           12345
           Oma + Opa
           12345
           Saats Pizza
           12345
           Shell
           12345
1625
