Community Member
7975 upgrade - tries to load "term75.default.loads" twice?
I have a 7975 which i keyed up a factory reset on. it goes to the upgrading screen, then goes to load term75.default.loads, comes up with an Auth. Fail, and then instantly tries the exact same file once more on a new screen. (the two screens come and go within  couple of seconds) Then it goes to the Cisco splash screen and sits there for ages with a circle symbol in the corner which has a dot in the center, then reboots, then over again. I have tried to change it to load SCCP75.8-5-4S.loads in telephony-service, and that file has also been tftp-server-flashed, but everytime I reboot the phone it does the same thing. Have I missed anything?
Here is the output from TFTP debug:
Apr  4 12:25:13.989: TFTP: Looking for term75.default.loads
Apr  4 12:25:13.989: TFTP: Opened flash:/Phones/7975/term75.default.loads, fd 10, size 654 for process 380
Apr  4 12:25:13.993: TFTP: Finished flash:/Phones/7975/term75.default.loads, time 00:00:00 for process 380
Thanks!
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
That happens because term75.default.loads uses a version that is too new for the phone to update to (search "auth fail").
Give it a correct term75.default.loads version, have it update, then update again to a newer version.
Community Member
Re: 7975 upgrade - tries to load "term75.default.loads" twice?
Hi Paolo,
Thanks for your fast reply. Is there any way I can find out what version it is requiring? The phone came from a different system and is now on ours, so I am unsure as to which version of term75 it wants. It could even need a firmware downgrade and not an upgrade, correct?
Thanks!
Nic.
As Rob mentioned below (rated).
8.5.2 is currently free from excessive enforcements for download.
Community Member
Great Help. I brought my IP
Great Help. I brought my IP phone alive !!!
5 Points each. Keep up good work.
Hall of Fame Super Red
Hi Nic,
Paolo is most correct here (+5 "P" )
TFTP - Auth Fail shows on phones (they must be @ 8.5(2) before moving
to the 8.5(4) you have loaded. So you need an interim version as a first step.
Firmware Upgrade Issues for SCCP
Note For all SCCP firmware upgrades from firmware release versions earlier than 8.3(3) to version 8.5(3) or greater, you must first upgrade your firmware to version 8.5(2). Once you have upgraded to version 8.5(2), you can upgrade your IP Phone to version 8.5(3) or later.
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/firmware/8_5_3/english/release/notes/7900_853.html#wp57602
Cheers!
Rob
Note: make sure to use the base 8.5.2 not 8.5.2sr1
Community Member
Thank you so much guys! You're both lifesavers! 5 stars each. Explained and solved my problem perfectly
2226
