7985 idle url not works
Hi people
We have a CUCM 7.0.2 and CIPC, 7970 and 7985
We have an application run on services url
We set idle url on CIPC 7970 and 7985. All phones works fine, but on 7985 the url idle not works.
On CUCM there is the field but the 7985 supports url idle?
Peterson
1 ACCEPTED SOLUTION
Re: 7985 idle url not works
That phone model does not support the idle URL config
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
1 REPLY
java
java
186
