7985 Phone Keeps Restarting
Hello, I'm testing out CUCM 8.6.2a in my lab and have run into a curious bug.  I have statically configured a 7985 video phone to register with my lab ccm, and the phone keeps restarting.  I have added the latest firmware to CUCM for the 7985 phones, however the phone does not reach the TFTP download screen.  I have checked and re-checked the ip settings as well as the switchport confi,g and switched patch cables.  None of those items seem to be the problem. In addition, I have 3 statically configured 7975 phones that work without any issues.  Any suggestions?
LB
Everyone's tags (5)
Blue
Try to do erase configuration in ip phone and do the above process again. Also restart your CUCM tftp services.
Ronak Patel
Plese rate helpful posts by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Ronak,
     Thanks for your reply.  Unfortunately, I have done this several times with no change. I will open a TAC case to see if this is a bug of some sort.
Hall of Fame Super Gold
Can you ping from CM to phone ?
Paolo,
     Thanks for your reply. Although the phone is stactically configured with an IP, it is not pingable due to the constant restarting/resetting.
If static doesn't work, try dhcp.
Thanks, that will be my next step.
Tried DHCP, still having the same issue.  There appears to be an issue between the 7985 phone and CUCM 8.6.2A.
604
