7985G Background image CCMgr 5.1
tgurney
Unable to get new image to 7985.
I've placed the image in tftp/Desktop~
List.xml in the TFTP directory seems right .... ?????
Jaime Valencia
you sure you're doing EXACTLY as the doc says??
Maintain and Operate Guides
http://www.cisco.com/en/US/products/hw/phones/ps379/prod_maintenance_guides_list.html
the config is Case Sensitive and you need to match the exact size and format for the image files
javalenc
if this helps, please rate
java
OK, Did not match that doc exactly but now we have it working ok. User can select from image options. Is there a way to push an image to the phone as the default.
something that has been asked several times before, unfortunately it's not possible
javalenc
java
