79xx call logs: missed/rec'd/placed - increase log size?
My apologies if this has been asked previously, I cannot find a similar thread.
- Is it possible to increase the log size from the default 100 records to 1000?  Or is this limited because of available resources of the device?
- If it cannot be increased, can it be redirected to a syslog server for permanet storage?
I believe this information is more or less duplicated in CDR however I find those reports nearly useless due to the fact that the "Email Report" is very nearly incomprehensible and the Online Results are painstakingly slow to click through one at a time.
CUCM: 6.1.4
Devices:  Mix of 7961/7970
Richard.
Re: 79xx call logs: missed/rec'd/placed - increase log size?
The answer to both questions is no, there is no way to increase the log and there is no way to configure this to send the info to another server.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Pretty much what I expected.
Thanks for the quick reply!
RR
158
