Community Member
79XX phone screensaver
I wanted to know if we can put some text info as the screensaver on the phones. All the docs I have read deals with images as screensavers. Or is the only way to get text is to convert an image of text?
thanks
1 REPLY
VIP Super Bronze
Re: 79XX phone screensaver
Sure but you will need to use the XML SDK and built your own application to do it. There is an Idle URL parameter at a global and per-device level. You can specify the URL the phone should open after a defined period of inactivity. If it's just text, you just need a web server that will serve up a properly formatted XML file.
143
