8.6 Extension Mobility not working
Ven Taylor
Level 4
Level 4
I've followed the configuration guide for extension mobility, (using a 7925G wireless phone) but when I try to login, (On phone, choose services / choose extension mobility)  I get Warning / Not Available.
When I unsubscribe the phone, the Extension Mobility service goes away on the phone, so I know that part is right.
Does anyone know what I'm missing?
Ven
Ven Taylor
5 Replies 5
Jaime Valencia
Does it work in other phone models?
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Unfortunately, it's the only phone type we have here, so I can't tell.
Ven
Ven Taylor
Is the Extension Mobility service activated/started? Have you completed all of the tasks in the configuration checklist?
Please remember to rate helpful responses and identify helpful or correct answers.
Hi Van
I know it is quite dated but we have just discovered this issue at one of our sites with the 7925 phones.
Did you ever end up sorting it out? What was the solution?
Other model phones at the site (desk phones) seem to be working ok.
Look forward to hearing from you if you receive this.
Many thanks in advance!
Johnny
Hi there
First thing you should check the configuration for EM and the associated UDP for 7925. Also the most important thing is to verify the database replication (from PUB) between the nodes are good (2)
utils dbreplication runtimestate
https://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/200396-Steps-to-Troubleshoot-Database-Replicati.html
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
