8-port BRI network module for Voice
I need the part number of 8-port BRI network module that can be used for voice. The NM will be connected to a 2851 router.
Thank you,
Ricky
Bronze
Re: 8-port BRI network module for Voice
Hi Ricky,
unfortunately there are only 8-port data BRI network modules available.
i think you have to insert 4x VIC-2BRI-NT/TE to reach your 8-port voice BRI in the 2800 series.
http://www.cisco.com/warp/public/788/products/2isdn_bri_vic.html
we had the same problem in several remote offices...
cheers, oliver
Thank you very much.
Hall of Fame Super Gold
the other alternative is that you use 1 x EVM-HD-8FXS/DID with 2 x EM-4BRI-NT/TE.
This will give you in additional 8 FXS port that you may or not want, but it is all contained into a single NM slot:
http://cisco.com/en/US/prod/collateral/modules/ps2617/prod_qas0900aecd8016c487_ps5855_Products_Q_and_A_Item.html
302
