802.1x and Voice Vlans
Hi all,
I have siemens optipoint 420.  I'm trying to see if there is a way the voice vlan can bypass the 802.1x authenication. My current port configuration look like this.
interface FastEthernet0/5
switchport access vlan 194
switchport mode access
switchport block multicast
switchport block unicast
switchport port-security
switchport port-security violation restrict
no snmp trap link-status
dot1x pae authenticator
dot1x port-control auto
dot1x violation-mode protect
dot1x timeout reauth-period 500
dot1x timeout tx-period 3
dot1x reauthentication
spanning-tree portfast
spanning-tree bpduguard enable
1 REPLY
Green
Re: 802.1x and Voice Vlans
hi
Do you know if your phone supports 802.1x authentication?
network mac-auth bypass
i recommend you to configure mac auth bypass
https://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_52_se/configuration/guide/sw8021x.html#wp1062454
2581
