802.1x on Alcatel Lucent IPtouch 2048 with Cisco 2960X
HI All,
I got stuck in the middle of the solution where we need to connect Alcatel lucent IPtouch 2048 phone to cisco switch port and from phone PC is connected.
We are trying to bypass authentication for IP phones, we dont want to do MAB/Dot1x/WEB authentication for these phones. Only PC should get authenticated but we are unable to achieve it.
Configuration of switch is as below
aaa authentication login default local
aaa authentication dot1x default group radius
aaa authorization network default group radius
aaa session-id common
switch 1 provision ws-c2960x-48lps-l
vtp mode transparent
dot1x system-auth-control
spanning-tree mode pvst
network-policy profile 1
voice vlan 171
vlan internal allocation policy ascending
vlan 22
name mgmt
vlan 7
name data
vlan 11
name voice
lldp run
interface FastEthernet0
no ip address
shutdown
interface GigabitEthernet1/0/1
switchport trunk allowed vlan 22,7,11
switchport mode trunk
switchport nonegotiate
interface GigabitEthernet1/0/2
shutdown
interface GigabitEthernet1/0/3
switchport access vlan 7
switchport mode access
switchport voice vlan 11
authentication host-mode single-host
authentication priority dot1x mab
authentication port-control auto
authentication periodic
authentication timer reauthenticate 18800
dot1x pae authenticator
spanning-tree portfast
spanning-tree bpdufilter enable
spanning-tree guard root
radius-server host x.x.x.x key 7 070871481F4D1E1712131F
radius-server host y.y.y.y key 7 011456000A4F011D244D5A
radius-server host x.x.x.x auth-port 1812 acct-port 1813 key 7 0201545F5A420833494F1D
radius-server host y.y.y.y auth-port 1812 acct-port 1813 key 7 121E5513434F0B162F2A30
radius-server deadtime 10
radius-server key 7 03030B0F574B265E4B080D
radius-server vsa send authentication
Please help me to resolve the issue.
638
