dm
881-v as pstn(fxo)-voip gateway?
Hello!
This can be very stupid question, but I can't find any info.
881-V description says :
(FXO) port for public-switched-telephone-network (PSTN) fallback
Is it possible to use it for pstn-voip gateway purposes as any other cisco or any restrictions?
Thank you!
  • IP Telephony
2 ACCEPTED SOLUTIONS
Hello,Yes it can be used as a
Yes it can be used as a Voice gateway . Look at this :-
http://www.cisco.com/c/en/us/products/collateral/routers/887-integrated-services-router-isr/data_sheet_c78_459542.html
Hope this helps!
Karthik Sivaram
Yes that is right similar to
Yes that is right similar to other voice gateways...
Hope this helps!
Karthik Sivaram
dm
Thank you!
Thank you!
dm
by the way, I readed link you
by the way, I readed link you provided and there is only info about
no info about using FXO for gateway purposes... :-(
look at Table 8  in the same
look at Table 8  in the same doc   under feature  " Cisco Voice Gateway" that is where you need to look
dm
thank you! so, to be
thank you!
 so, to be completely sure, FXO port in 881-V has the same functionality as in, let's say, 1760, right?
180
