09-24-2017 01:34 PM - edited 03-17-2019 11:13 AM
I installed CUCM and ipphone 8811 , 7861 and 7811
I configured phone button template for 8881 ,7861 and 7811.
for example i can add 10 speed dial button for 8811 . But i can see only left button (5 SD) on the phone. i can not see righ button.
You can see CUCM and ip phone version .
How can i resolve this problem ?
CUCM System version: 11.5.1.10000-6
rootfs88xx.11-5-1-18 | ||
Boot load ID | sb288xx.BE-01-019 | |
Version | sip88xx.11-5-1-18 | |
Hardware revision | V01 |
App Load ID | rootfs78xx.11-5-1-18 | |
Boot Load ID | sboot78xx.11-5-1-18 | |
Version | sip78xx.11-5-1-18 | |
Hardware Revision | 33
Hardware Revision | 35 |
Solved! Go to Solution.
09-25-2017 05:45 AM
Set the "Line Mode" setting on the device to "Enhanced Line Mode" which will allow you to use the 5 sessions buttons as line buttons instead.
09-26-2017 01:09 PM
09-26-2017 03:27 PM
That feature is only available on 88XX models. Other models you are limited to the line buttons as they are only at this point.
09-28-2017 11:43 AM
09-25-2017 05:45 AM
09-26-2017 01:09 PM
09-26-2017 03:27 PM
09-28-2017 11:43 AM
10-09-2017 06:40 PM
set line mode on enhanced line on device page to resolve this issue
