10-31-2013 02:55 PM - edited 03-16-2019 08:11 PM
Is 8831 conference phone compatible with UC540 system?
10-31-2013 03:07 PM
Yes, it's supported by CME. You can read this datasheet
The phone is supported on Cisco Unified Communications Manager Express (CME) Versions 15.3(2)T, PI21, 15.3(3)T, PI22, and later.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps12965/data_sheet_c78-726887.pdf
Please remember to rate useful posts clicking on the stars below.
Favor calificar todos las respuestas útiles dando click en las estrellas de mas abajo.
___________________________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
10-31-2013 03:12 PM
8831 uses SCCP, to register to UC540, then right?
10-31-2013 03:09 PM
Yeah CME, but on UC540 smb system too??
10-31-2013 03:14 PM
8831 use SIP not SCCP to register to UC540.
UCS540 runs CME. CME is the IOS's feature.
10-31-2013 03:23 PM
I think I read where SIP phones (Cisco phones) not TAC supported deployment in UC540.
Is this true? Only SPA phones with UC540 are TAC supported ?? True/False
10-31-2013 03:59 PM
False. You can register Cisco's phone running SIP and they will be supported by TAC. Third party phones are another deal!
Just need to read Call Manager Express documentation to know which phones are supported.
10-31-2013 04:01 PM
Actually that link is incorrect, here's the bug:
In 8831 Data sheet support of 8831 phones info in CME-10.0 is incorrect
Currently it's not supported on CME, it might be in the future, but it's not supported with SMB products.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
11-01-2013 07:05 AM
What model conference phone do you recommend that will work with UC540?
11-01-2013 07:29 AM
Hi Jeanie,
In addition to the great help from Java and Leo (+5 folks)
I think your next best bet would be the 7937 which is supported on the
UC5xx series;
Sadly, it has recently been announced as EoL (end of life) but you don't have
many options;
Cheers!
Rob
"Why do the best things always disappear "
- The Band
11-01-2013 07:36 AM
Yeah, I'm recommending that my customer consider going ahead and replacing the the UC540.. Cisco 7937 has EoS/EoL milestone out there now too!! http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps379/end_of_life_notice_c51-729487.html
THANKS TO EVERYONE FOR YOUR INPUT!!!!!
