Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
8841 and SRST
i'm trying to find information about the phone 8841 and the srst support.
If i check the release notes for the phone firmware, i see that the SRST version required is "SRST 8.0 (IOS load 15.1(1)T) and above" as you can read in the document http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/8841_8851_8861/firmware/10-2-1/english/ReleaseNotes/P881_BK_R7A58C22_00_rn-10_2_1-8841-8851-8861/P881_BK_R7A58C22_00_rn-10_2_1-8841-8851-8861_chapter_00.html
If i check the SRST 10.5 datasheet the phone 8841 is not mentioned in the phones supported http://www.cisco.com/c/en/us/products/collateral/unified-communications/unified-survivable-remote-site-telephony/data_sheet_c78-678873.html
So is the phone 8841 supported for SRST or not? And if yes, in what SRST version is supported?
thanks and regards,
Christian
Everyone's tags (1)
1 ACCEPTED SOLUTION
Hi.As you have seen in your
Hi.
As you have seen in your first link, they are supported from srst Version 8.0 as they are treated as SIP endpoints
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi.
Carlo
Thanks Carlo, i'm wondering
Thanks Carlo,
 i'm wondering why Cisco have to confuse people by writing different information for the same matter.
Christian
1161
