88xx Icons Missing in CCMAdmin
I've just applied the latest device pack ( cmterm-devicepack9.1.2.12045 ) to my 9.1 cluster to enable support for the new handsets. Support for the new handsets works fine, except for a trivial issue in CCMAdmin: There are no icons for the new 88xx phones!
Missing Icons
Is this a known feature? I can't see anything in BugTrack.
GTG
Please rate all helpful posts.
Hi GordonI hope you are doing
Hi Gordon
I hope you are doing well.
After you apply device pack , did you restart  the Pub , and subscriber if you have existing subscriber ?.
*to apply a device :
A-Apply on all nodes
B-Reboot all nodes in cluster starting from Publisher
please rate all useful information
Yes, 'cause if I hadn't, the
Yes, 'cause if I hadn't, the phones wouldn't have registered.
GTG
Purple
This could be a cosmetic bug
This could be a cosmetic bug.
suggest opening TAC case since the fimrware 10.2(1) has also lot of bugs.
regds,
aman
I'm having a bad year with
I'm having a bad year with TAC & Bugs. I can live with this bug. If someone else wants the fight, feel free to take up the challenge...
GTG
54
