8941 not registering in call manager 7.1.5.33900-10
Charles Ngalle
                   I have an IP phone 8941 and the phone does not register under the clients or team or wan device pool in CUCM 7.1.5. I am able to register and configure the phone under the device pool Change_me_now and make phone call. the specification of the device pool is as follow. Does anyone had a similar issue?
Device pool name* Change_me_now
CUCManager group IRT-GRP1
CSS for autoregistration: CSS5
Reverted call Focus priority: Default
Local Route Group : <none>
Team Pool
Device Pool Name IRT-Team
CUC Manager Group IRT-GRP2
CSS for autoregistration:CCS5
Reverted Call Focus priority: Default
Local Route Group:<none>
Charles
10 Replies 10
Chris Deren
What are the CUCM servers listed in each of the CUCM Groups?
Are all the servers online and have CUCM service running?
Chris
Hello Chris,
I have a Pub CUCM1 and a Sub CUCM2 and they all have CUCM service running.
Charles
So, after the phone registers with the Change_me_now DP and if you change the DP to somethign else it no longer registers?
What does the phone say in the status log?
Chris
Hello Chris,
The phone is still sitting trying to obtain an ip address from the DHCP server.
Charles Ngalle
IT Support Specialist
Terminus 200
3333 Piedmont Road, Suite 2050
20th floor Atlanta GA 30305 U.S.A
T +1 4047369415 F +1 4047369250
cngalle@servcorp.com
SERVCORP.COM<>
View Worldwide Locations»<>
<>[http://www.servcorpdirect.com/servcorpsign/images/logos/f.jpg]<>[http://www.servcorpdirect.com/servcorpsign/images/logos/t.jpg]<>[http://www.servcorpdirect.com/servcorpsign/images/logos/in.jpg]<>[http://www.servcorpdirect.com/servcorpsign/images/logos/ut.jpg]<>[http://www.servcorpdirect.com/servcorpsign/images/logos/l.jpg]<>
This makes no sense. Are you chanign anything on the physical phone itself or just configuration on CUCM?
When you look at the network settings on the phone do you see DHCP server, IP address, etc?
Chris
Hello Chris,
I agree, it does not make sense, the phone is showing an ip address, a default router, dns server as well. I enable alternate TFTP so I can use the CUCM of that location and the phone is showing a TFTP server 1 and TFTP server 2 ip addresses.
Charles Ngalle
Terminus 200
SERVCORP.COM<>
Hello Chris,
I am checking the device in call manager, the phone is getting an ip address but has a status of unregistered.
Charles Ngalle
Terminus 200
SERVCORP.COM<>
OK, so it is getting IP address.
Is TFTP service running on the other CUCM? can you try using the same TFTP?
Chris
Yes I can.
I do have several call manager installed, in Atlanta, Chicago and California. When I register the phone in Atlanta and Chicago the phone is working fine and I can make phone calls. However When I am connecting the phone to California the phone is only registering when using the device pool change_me_now. If I change the device pool to team or client, the phone is not registering.
I just changed my device pool now to change_me_now and the phone registered with a telephone number and I can make phone calls. If I have to assign this phone to a client using device pool IRT_client, the phone just stay does not complete the registration process.
Charles Ngalle
Terminus 200
SERVCORP.COM<>
Hello Chris,
I was able to resolve my issue and thank you for your assistance.
Cheers,
Charles Ngalle
Terminus 200
SERVCORP.COM<>
