Community Member
8941 phone issue
Problem with 8941 phones,intialy phones get registered to CUCM 9.1  working fine
after applying device pack  78XX....8941 phones  showing upgrade i troubleshooted all the basic things i am wondering what could be the problem.
Community Member
8941 phone issue
Can any body suggest on this
8941 phone issue
Was the cluster reboot done after applying the device pack on all the servers?
Can you try restarting the TFTP service on all the TFTP servers as well.
What is the exact message on the display of 8941 IP phones?
Are all of these phones remote to the TFTP server or even the phones local to the TFTP server facing the issue?
Manish
Community Member
8941 phone issue
Hi Manish,
The cluster done multiple reboots & tftp service restarted several times,i am facing this issue after applying 7821 device pack,themessage 8941 showing stii upgrade.the phones are local.
Community Member
8941 phone issue
Still the phone showing upgrading i did all the basic things,around 50 phone to deploy can any one recommend on this
Purple
8941 phone issue
Hi Siva,
what is the firmware version of 8941 IP phones and exact CUCM version ?
regds,
aman
Community Member
8941 phone issue
Hi Amon,
We are using CUCM verison 9.1 & the firmware version for 8941 is SCCP8941_8945.9-4-1-9,i have been reigisters to sccp.
except this phone modles all device are registered,i am facing this issue after applying device pack for 7821.
Silver
8941 phone issue
Siva,
Is that the firmware the phones are running or the firmware they're trying to upgrade to?  You may be jumping too many versions at once.
Brian
Purple
8941 phone issue
Hi Siva,
If u are using CUCM version 9.1(2) with 9.4(1) for 8941 , u require a Device pack for the phone to work.Even though it was working earlier, can u check for Device Pack?also, share show version active
Also, cross-check as Brian has suggested.You can login through CLI  and run file list tftp *8941* to check the available firmwares.
regds,
aman
Community Member
8941 phone issue
HI Amon,
Thanks for your reply,
I will download device will check it.
show version active
Active Master Version: 9.1.2.10000-28
Active Version Installed Software Options:
cmterm-8941_8945-sccp.9-4-1-9.cop
cmterm-android_9.1.1v1.cop...
Community Member
8941 phone issue
Hi Brain,
I am trying to upgrade latest firmware version..
Community Member
8941 phone issue
Hi ,
The issue resolved finally all my 8941 phones are registered
Purple
8941 phone issue
Hi Siva,
What u did ?
please share.
regds,
aman
Community Member
8941 phone issue
Hi Amon,
The issue with firmware file.just uploaded the cmterm-894x-sccp.9-1-2-00.cop.sgn file & restarted my tftp server,
my phones got registered.
529
