8945 Phone
I am attempting to add a new model to cucm but it isn't listed in the drop down menu of phones. Is there a way to update the phone list or somehow add  a template for the 8945 phone?
1 ACCEPTED SOLUTION
Blue
8945 Phone
HI
1) You have to install qed file cmterm-894x-qed.9-1-2-11.cop.sgn
2) after that install firmware cmterm-894x-sccp.9-1-2-00.cop.sgn
http://www.cisco.com/web/software/282074289/48135/cmterm-894x-sccp.9-1-2-00-readme.html
You need  qed file to enable this device in the CUCM 8.5
Ronak patel
Please rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Super Bronze
8945 Phone
You can download and install the latest 'device pack' for your version of CUCM to install new device types. CHeck the release notes on the download to see if the phone type you need is included - some have minimum CUCM versions so even the latest dev pack for that version may not include the type you need.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
8945 Phone
I figured it was something easy.
Current Version:
Cisco Unified CM Administration
System version: 8.5.1.11900-21
So the Device Pack 8.5.1 (14059-1) - should do the trick correct?
Blue
8945 Phone
HI
Ronak patel
307
