06-12-2012 10:18 PM - edited 03-16-2019 11:38 AM
We have recently configured and setup a new VOIP phone model - 8961 onto our call manager system version 7.1.5, UCCE version - 7.63
All our previous phones are SCCP phones. This model is setup as a SIP phone.
After adding it to our UCCE Application user to intergrate it with Cisco Agent desktop, it fails to login. Observer that on login to Cisco Agent Desktop it hangs at Connecting to CTIOS Server and then timeouts out with error : The request failed because a timeout exceeded
I believe there may be some config that needs to be added in order for SIP phones to work, but not sure.
Anyone have some advice on what is stopping it from working?
08-29-2012 08:17 AM
I'm running into the same problem.
How did you solve this issue?
kind regards
Markus
08-31-2012 01:45 AM
Hi Markus,
You got to add some user group permissions on the application user for UCCE in Call Manager,
Try adding:Go to :
User Management >> Application User >> Choose App User >> Add user to group
Choose:
Standard CTI Allow Control of Phones supporting Rollover Mode
Control of Phones supporting Connected Xfer and conf
04-04-2013 08:38 AM
did it fix your problem?.. I have same issue...help
04-05-2013 06:30 PM
Hi Edgar,
Yes it did, have you tried:
Choose:
05-24-2018 07:47 AM
I appear to have the same issue with UCCE/CUCM v11.5 My application user is associated to the 8961 device and has roles for:
What am I missing?
Thank you,
Tony
05-24-2018 08:14 AM
Hi there
Choose:
Also, the defect CSCty88472 and try JAL and DTAL is disabled at the phone level else set Agent Phone Line Control to all lines.
Hope this helps!
Cheers
Rath!
***Please rate helpful posts***
