8961 call features don't work on CME 10.0
Hi all,
I installed the 8961 using sip on CME 10.0, and I have configured the feature-buttons on the template which includes call pickup.
these feature buttons can display on the screen. But when I use these buttons, I get the busy tone, that means these feature buttons don't work.
Otherwise all configuration under voice register template X - will not be displayed on the phone.
Are there any other setting steps for using these call features?
Also if I press cfwd all softkey after pressing the first digit I will get an busy tone. Anybody has an hint to solve the issue ?
Stefan
Everyone's tags (3)
sh run output: 2911Fabi#sh
sh run output:
2911Fabi#sh run
Building configuration...
Current configuration : 4594 bytes
! Last configuration change at 11:24:07 UTC Mon Jun 30 2014 by cisco
version 15.3
hostname 2911Fabi
boot-start-marker
boot system flash c2900-universalk9-mz.SPA.153-3.M3.bin
boot-end-marker
aqm-register-fnf
enable secret 5 $1$y/9B$dyQFexGqpq3RQucFhEG2p.
enable password cisco
no aaa new-model
no ip routing
no ip cef
no ipv6 cef
voice-card 0
voice rtp send-recv
voice service voip
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 fax protocol pass-through g711alaw
 modem passthrough nse codec g711alaw
 sip
  bind control source-interface GigabitEthernet0/0
  bind media source-interface GigabitEthernet0/0
  registrar server expires max 120 min 60
voice class codec 1
 codec preference 1 g711alaw
 codec preference 2 g711ulaw
 codec preference 3 g729br8
 codec preference 4 g729r8
voice class custom-cptone leavetone
 dualtone conference
  frequency 500 2500
  cadence 300 400 500
voice class custom-cptone jointone
 dualtone conference
  frequency 500 1200
  cadence 300 200 400
voice register global
 mode  cme
 source-address 10.137.240.127 port 5060
 privacy-on-hold
 max-dn 200
 max-pool 42
 call-forward system redirecting-expanded
 call-feature-uri cfwdall http://10.137.240.127/cfwdall
 phone-redirect-limit 20
 tftp-path flash:
 create profile sync 0185744153262714
 overlap-signal
voice register dn  1
 number 100
 pickup-group 1
 name Michal Mandak
 huntstop
 label Michal Mandak
voice register dn  2
 number 6022
 pickup-group 1
 name Stefan 6022
 huntstop
 label STefan 6022
voice register dn  3
 number 161
 pickup-group 1
 name Jan Jilma
 label Jan Jilma
voice register template  1
 dialplan 1
 softkeys idle  Newcall Redial Cfwdall Pickup
voice register dialplan 1
voice register pool  1
 busy-trigger-per-button 1
 id mac 5478.1AE0.E122
 feature-button 1 PickUp
 type 8961
 number 1 dn 1
 template 1
voice register pool  2
 busy-trigger-per-button 2
 id mac 203A.0783.A2A9
 type 8945
 number 1 dn 3
license udi pid CISCO2911/K9 sn FCZ16446090
hw-module pvdm 0/0
hw-module pvdm 0/1
username admin privilege 15 password 0 cisco
username c privilege 15 password 0 c
username cisco privilege 15 password 0 cisco
redundancy
interface Embedded-Service-Engine0/0
 no ip address
 no ip route-cache
 shutdown
 ip address 10.137.240.127 255.255.255.0
 no ip route-cache
 duplex auto
 speed auto
 no mop enabled
interface GigabitEthernet0/1
 no ip address
 no ip route-cache
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/2
 no ip address
 no ip route-cache
 shutdown
 duplex auto
 speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.137.240.254
ip sla responder
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer voice 10 pots
 preference 1
 destination-pattern 0.
dial-peer voice 20 voip
 preference 1
 incoming called-number .
gatekeeper
 shutdown
telephony-service
 sdspfarm conference mute-on 11 mute-off 11
 sdspfarm units 3
 sdspfarm unregister force
 sdspfarm tag 1 confdsp1
 no auto-reg-ephone
 max-ephones 42
 max-dn 200
 ip source-address 10.137.240.127 port 2000
 timeouts interdigit 6
 time-zone 23
 time-format 24
 date-format dd-mm-yy
 max-conferences 3 gain -6
 call-park system application
 call-forward pattern .T
 multicast moh 239.1.1.1 port 16384
 web admin system name dk password adm4cmeDK
 dn-webedit
 time-webedit
 transfer-system full-consult
 transfer-pattern .T
 secondary-dialtone 0
 fac standard
 create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn  12
 number 6012
ephone-dn  13
 number 6013
ephone-dn  14
 number 6014
ephone  12
 mac-address 0014.6A87.7BF3
 type 7960
 button  1:12
ephone  13
 mac-address 0024.C40C.9304
 type 7942
 button  1:13
ephone  14
 mac-address 5478.1A6B.416A
 type 6961
 button  1:14
line con 0
 login
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 password cisco
 login local
 transport input all
scheduler allocate 20000 1000
end
Hi @stefan-walter,In the
Hi @stefan-walter,
In the telephony-service configuration, type the following:
telephony-service
 service directed-pickup gpickup
 cnf-file location flash:
 cnf-file perphone
 no create cnf-files
 create cnf-files
Also, you can remove the feature-button from the voice register pool 1 if you want.
Let me know if that help you. It worked for me.
Rgrds,
Martin, IT Specialist
204
