Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
89xx 99xx Edit Dial Softkey CM 8
Greetings,
Does anyone know if there is a way to add the Edit Dial softkey for the 89xx/99xx phones?  I have a customer with CM 8.6 using the new 89xx/99xx phones and when you go into the missed call directory on the phones, the is no Edit Dial softkey to allow you to prepend a 9 or a 91.
I would either like to add the softkey, or find a way to add the 9 to incoming calls.  I have added the 9 automatically under the CM Service Parameters previously for other customers with PRI's, but this customer has SIP from an ITSP.  I am worried if I use the default 9 prepend options I may cause issues with CCX doing database dips for customer information.
Any thoughts?
Thank you,
Brian
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Hi Brian,
I don't have one of these phones in front of me, but I'm wondering if this is
applicable?
Edit Number From Call History
1. Press the Applications button .
2. Select Call History. (Use the Navigation pad and Select button to scroll and select.)
3. Highlight the call you want to edit.
4. Press the EditDial softkey. (You may need to press More softkey first.)
5. Press the right or left arrow on the Navigation bar to move the cursor to the desired location.
6. Press the softkey to delete numbers on the left of the cursor.
7. Press the Call softkey to dial the new edited number.
8. Press the return softkey to return the Call History screen.
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/9971_9951_8961/8_0/english/user/guide/book/apps_rt902.html#wp1011242
Cheers!
Rob
Hi Brian,
applicable?
Cheers!
Rob
The guide you found is correct Rob.  Turns out the users were using the touchscreen on the 9971's to touch the call in the list.  When you touch it dials out instead of giving your further options.  Key is to use the buttons to select the call.
Thanks!
Brian
1153
