9.1 BAT
Dears,
I get the error attached when i am trying to add " No of access control groups" or "No of Controlled devices" in BAT file.
also attaching the BAT file.
1 ACCEPTED SOLUTION
Hall of Fame Super Red
9.1 BAT
Hi Clark,
Sounds like it could be this bug;
bat_9.1.1.1000-11.xlt Excel error in Users tab on adding Controlled item
CSCud91003
Symptom:
User sees "Application-defined or object-defined  error" when attempting to enter a value for the Number of Controlled  Profiles, Number of Controlled Devices, Number of Access Control Groups  or Number of CTI Controlled Profiles in the Users tab of the  bat_9.1.1.10000-11.xlt Bulk Administration Tool spreadsheet. The columns  are not added to the spreadsheet.
Conditions:
User  wants to set the Number of Controlled Profiles, Number of Controlled  Devices, Number of Access Control Groups or Number of CTI Controlled  Profiles fields to a value greater than zero, so they may enter data for  those columns in the bat_9.1.1.10000-11.xlt spreadsheet.
Workaround:
Manually add columns and data after exporting to comma separated value text file.
Cheers!
Rob
"Seek it out and ye shall find  "
- OneRepublic
9.1 BAT
Hi Clark,
CSCud91003
Symptom:
Conditions:
Workaround:
Cheers!
Rob
- OneRepublic
9.1 BAT
Thanks Rob,
I used 8.6 BAT and it worked luckily i was surprise, as i have seen many threads saying that BAT matters for version but it worked for me.
153
