Community Member
9.@ wildcard for GBNP no longer working
Something strange happened, all of a sudden, my route pattern 9.@ that used the GBNP is no longer working.  I used DNA and it doesn't look like its matching any calls.
This may have happened after I migrated the CUCM to VMWare.  The DRS restore said everything restored correctly.  Perhaps there were files that were missing??
Has anyone had this issue before?
I'm running CUCM 8.5.1 btw.
Re: 9.@ wildcard for GBNP no longer working
Have you tried reinstalling the GBNP??
java
if this helps, please rate
www.cisco.com/go/pdi
Community Member
Hey Jaime, thanks for the reply.  How would you go about reinstalling the GBNP? Is it just a matter of going to the Dial-Plan Installer, clicking uninstaill, and then installing it again?
Vince
158
