07-18-2012 01:51 PM - edited 03-16-2019 12:16 PM
I seem to be having an issue with dialing 911. User is getting dialtone after dialing 911. Here is my config.
dial-peer cor custom
name PSTN
name PBX
name VOIP
dial-peer cor list TargetPSTN
member PSTN
dial-peer cor list TargetPBX
member PBX
dial-peer cor list TargetVOIP
member VOIP
dial-peer voice 98 pots
corlist incoming TargetPBX
corlist outgoing TargetPSTN
destination-pattern 911
incoming called-number 911
port 0/0/1:23
forward-digits 3
dial-peer voice 99 pots
port 0/0/0:23
forward-digits all
Thanks in advance.
Solved! Go to Solution.
07-19-2012 08:42 AM
Mike
Can you remove the COR
and test again
no corlist incoming TargetPBX
no corlist outgoing TargetPSTN
Alex.
Please rate useful posts.
07-18-2012 01:56 PM
Mike,
Can you post
debug isdn q931 of a failed call
Also the config or info about your sytem
CUCM or CME
Alex.
07-18-2012 02:01 PM
Actually its a temporary Gateway that we have between an NEC and the PSTN , so we can strip DIDs off as people migrate to CUCM. I will work on getting a debug.
Thanks.
07-18-2012 02:41 PM
Hi Mike,
Can you post a debug voip dial-peer and the q931 mentioned above.
Try adding direct-inward-dial to your dial-peers 98 & 99
HTH,
Chris
07-19-2012 07:13 AM
Here is the debug.
*Jul 19 10:18:15.507: ISDN Se0/0/1:23 Q931: RX <- CALL_PROC pd = 8 callref = 0xDFAE
Channel ID i = 0xA98397
Exclusive, Channel 23
*Jul 19 10:18:17.167: ISDN Se0/0/1:23 Q931: RX <- ALERTING pd = 8 callref = 0xDFAE
Progress Ind i = 0x8488 - In-band info or appropriate now available
*Jul 19 10:18:17.175: ISDN Se0/1/0:23 Q931: TX -> ALERTING pd = 8 callref = 0x8100
*Jul 19 10:18:20.831: ISDN Se0/1/0:23 Q931: RX <- SETUP pd = 8 callref = 0x0200
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9838D
Exclusive, Channel 13
Progress Ind i = 0x8181 - Call not end-to-end ISDN, may have in-band info
Calling Party Number i = 0xA1, '651XXXXXXX'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '911'
*Jul 19 10:18:20.843: %ISDN-6-CONNECT: Interface Serial0/1/0:12 is now connected to 651XXXXXXX N/A
*Jul 19 10:18:20.847: ISDN Se0/1/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0x8200
*Jul 19 10:18:20.847: ISDN Se0/1/0:23 Q931: TX -> CONNECT pd = 8 callref = 0x8200
*Jul 19 10:18:20.931: ISDN Se0/1/0:23 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x0200
*Jul 19 10:18:31.439: ISDN Se0/1/1:23 Q931: RX <- DISCONNECT pd = 8 callref = 0xDF9F
Cause i = 0x8190 - Normal call clearing
*Jul 19 10:18:31.439: %ISDN-6-DISCONNECT: Interface Serial0/1/1:0 disconnected from 4525 , call lasted 942 seconds
*Jul 19 10:18:31.443: ISDN Se0/1/1:23 Q931: TX -> RELEASE pd = 8 callref = 0x5F9F
*Jul 19 10:18:31.447: %ISDN-6-DISCONNECT: Interface Serial0/0/1:0 disconnected from 612XXXXXXX , call lasted 942 seconds
*Jul 19 10:18:31.451: ISDN Se0/0/1:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x8091
Cause i = 0x8090 - Normal call clearing
*Jul 19 10:18:31.499: ISDN Se0/0/1:23 Q931: RX <- RELEASE pd = 8 callref = 0x0091
*Jul 19 10:18:31.503: ISDN Se0/0/1:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8091
*Jul 19 10:18:31.539: ISDN Se0/1/1:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0xDF9F
07-19-2012 07:53 AM
Mike,
We see the call is incoming on
S0/1/0:23
Which dial peer do calls on PORT 0/1/0:23 match
Think you will need to provide more or all of show run
Alex.
07-19-2012 07:57 AM
network-clock-participate wic 0
network-clock-participate wic 1
network-clock-select 1 T1 0/0/0
network-clock-select 2 T1 0/0/1
ip cef
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
isdn switch-type primary-ni
voice-card 0
no dspfarm
voice service voip
allow-connections h323 to sip
allow-connections sip to sip
h323
modem passthrough nse codec g711ulaw
sip
voice translation-rule 3
rule 1 /7029/ /6515237029/
voice translation-profile profile1
translate calling 3
controller T1 0/0/0
framing esf
linecode b8zs
pri-group timeslots 1-24
description PRI coming from the PSTN
controller T1 0/0/1
framing esf
linecode b8zs
controller T1 0/1/0
framing esf
clock source internal
linecode b8zs
description To Switch
controller T1 0/1/1
framing esf
linecode b8zs
interface FastEthernet0/0
ip address 10.220.41.99 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
interface Serial0/0/1:23
no ip address
encapsulation hdlc
no cdp enable
interface Serial0/1/0:23
no ip address
encapsulation hdlc
isdn protocol-emulate network
no cdp enable
interface Serial0/1/1:23
no ip address
encapsulation hdlc
no cdp enable
ip default-gateway 10.220.41.1
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.220.41.1
ip http server
no ip http secure-server
logging 10.1.1.95
snmp-server community OSIMonitor RO 5
control-plane
voice-port 0/0/0:23
voice-port 0/1/0:23
voice-port 0/0/1:23
voice-port 0/1/1:23
name PSTN
name PBX
name VOIP
member PSTN
member PBX
member VOIP
dial-peer voice 6 pots
description Outbound
destination-pattern [2-9].........$
incoming called-number [1-7]...$
direct-inward-dial
port 0/0/0:23
forward-digits 10
dial-peer voice 7 pots
direct-inward-dial
port 0/0/1:23
forward-digits 10
dial-peer voice 8 pots
destination-pattern [2-9]......T
direct-inward-dial
port 0/0/1:23
forward-digits 7
dial-peer voice 9 pots
direct-inward-dial
port 0/0/0:23
forward-digits 7
dial-peer voice 10 pots
corlist incoming TargetPSTN
corlist outgoing TargetPBX
description Inbound Dialin
translation-profile incoming Outbound
destination-pattern [1-7]...
incoming called-number .
no digit-strip
direct-inward-dial
port 0/1/0:23
dial-peer voice 11 pots
no digit-strip
direct-inward-dial
port 0/1/1:23
dial-peer voice 22 pots
description Outbound LD
destination-pattern 1..........
no digit-strip
port 0/0/0:23
dial-peer voice 23 pots
no digit-strip
port 0/0/1:23
port 0/0/1:23
forward-digits 3
port 0/0/0:23
forward-digits all
dial-peer voice 411 pots
destination-pattern 411
incoming called-number 411
port 0/0/1:23
forward-digits all
dial-peer voice 36 voip
description Connection to CUCM
destination-pattern 6787
session protocol sipv2
session target ipv4:10.1.100.31
dtmf-relay h245-alphanumeric
dial-peer voice 35 voip
destination-pattern 7029
dial-peer voice 37 voip
destination-pattern 6631
dial-peer voice 38 voip
destination-pattern 6701
dial-peer voice 39 voip
destination-pattern 6618
dial-peer voice 40 voip
destination-pattern 6703
dial-peer voice 41 voip
destination-pattern 6612
dial-peer voice 42 voip
destination-pattern 6660
dial-peer voice 43 voip
destination-pattern 6641
dial-peer voice 44 voip
destination-pattern 6684
dial-peer voice 45 voip
destination-pattern 6705
dial-peer voice 46 voip
destination-pattern 6663
07-19-2012 08:10 AM
Mike
Can you add the following as Chris showed earlier:-
direct-inward-dial
direct-inward-dial
Test again
Alex.
07-19-2012 08:32 AM
Still failing. Here is the debug. Thanks.
*Jul 19 11:37:42.339: ISDN Se0/1/0:23 Q931: RX <- SETUP pd = 8 callref = 0x0100
Standard = CCITT
Channel ID i = 0xA98382
Calling Party Number i = 0xA1, '651XXXXXX'
*Jul 19 11:37:42.355: ISDN Se0/1/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0x8100
*Jul 19 11:37:42.363: ISDN Se0/1/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x8100
Cause i = 0x8281 - Unallocated/unassigned number
*Jul 19 11:37:42.471: ISDN Se0/1/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x0100
*Jul 19 11:37:42.475: ISDN Se0/1/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8100
*Jul 19 11:37:50.431: ISDN Se0/1/0:23 Q931: RX <- SETUP pd = 8 callref = 0x0100
Standard = CCITT
07-19-2012 08:42 AM
Mike
and test again
Alex.
07-19-2012 08:53 AM
That did it. Thanks.
Is there a resource for Dial-Peer config? Its either a practice thing or compreshension for me.
07-19-2012 09:01 AM
Mike,
glad it helped.
There are many sources of information for dial peers
here are a couple
http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/dial_peer/dpeer_c.html
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a008010fed1.shtml
Alex.
