Community Member
911 Notification without CER
Is there any way in Callmanager (6.1) to provide email notification of 911 calls without having Cisco Emergency Responder. Is this possible?
Re: 911 Notification without CER
sorry, not possible if you want that capability you need CER
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
Is it possible to get these records at least in CDR reporting? I have never been able to find them in there either. Is it at least possible to get the info on demand in CDR? Even if notification is not available outside CER.
that you can get, do a CDR search for what you dial, whether it's 911 or 9911
javalenc
java
210
