9951 cisco phone with phone designer software issue
i m working on windows 7 32bit laptop
my cucm manager version is 9.1.2.11900-12
i have 9951 cisco phone with the last version sip9951.9-4-1-9
when i choose wallpaper or ringtone , i receive "A communications failure occurred"
all check box is dun
my network is perfect and i have no firewall between vlans
any solutions guys????
tk
shoham
Check the config, if it still
Check the config, if it still fails, it might be due to your OS being not supported
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cupa/phone_designer/7-1/english/install/guide/Installation_Guide/PD1chapter.html
Client PC
Operating Systems: Microsoft Windows XP Professional, Microsoft Windows Vista Business Edition or
Enterprise Edition
Note Windows 7 is not supported.
java
if this helps, please rate
www.cisco.com/go/pdi
Hi Jaimewith windows xp i
Hi Jaime
with windows xp i receive the same issue......angry
Are you pointing to the
Are you pointing to the publisher node or a subscriber node?  Make sure to point to a node running CallManager/CTIManager service.
both......same issue.....my
both......same issue.....my friend from cisco told me that phone designer does not work at all with the new 99xx,78xx family phones.....
Phone designer works fine for
Phone designer works fine for me on my 9.1.2 cluster with a 9971.  Make sure web access is enabled on the phone as that is necessary.  Also check the phone's webpage to see that the authentication URL is set as.
TK Its working!!!
TK
Its working!!!
Hi JaimeIts works for me with
Hi Jaime
Its works for me with windows 7 64 bit!
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-application-designer/113552-phone-designer-00.html
122
