Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
9951 ip phone camera detected but not working
hi,
currently i have cucmbe 8.6 and registered 9971, 8941 and 9951 phone. Camera of 9971 and 8941 are working fine but camera of 9951 is showing message on phone screen "Cisco Unified Camera detected but disabled by the administrator".  Even though i enabled (and overide) the "Cisco Camera" and "video capabilities" and "back and side usb port". I did the same config for 9971 phone and its working but for 9971 phone i am getting the above message. the load version on 9951 is "sip9951.9-1-1SR1". IP Color expansion module is also connected to 9951 ip phone.
Re: 9951 ip phone camera detected but not working
hi,
On the device configuration of 9951, select the expansion module
CP-CKEM-C and reset the phone.
Hope this helps !
Karthik
ip color expansion module is working fine. but ip camera is giving the following error event though camera for 9971 is working fine "Cisco Unified Camera detected but disabled by the administrator"
hi,
Please install the latest firmware 9.2(4) on this phone.
Karthik
Did you ever get this resolved?  We have a similar issue and our 9951's are running 9-2-4ES-7.  Our 8945s are working properly, but the 9951s are not.  Same errors you mentioned and same settings (overrides to common phone settings).
Clyde
On the device page at Product Specific Configuration Layout try to disable the Power Negotiation
Leonardo Santana
No luck.  Same symptoms with it DISABLED as with Power Negotiation enabled (tried both).  As a side note, I have the phone powered with a brick right now...no PoE in use.
Clyde
hi,
yes i upgraded the firmware and my vlan was also not correct. after this the issue got resolved
1934
