9951 IP phone registration problem
Will appreciate if you can guide me here:
1. 9951 phones working fine with firmaware sip9951.9-0-1SR1
2. Added a new 9951 phone but it does not register as the firmware it is using is sip9951.9-2-2SR1-9
From: <sip:2823@172.29.27.250>;tag=c40acbe137ec00203f83cc41-4d566524
To: <sip:2823@172.29.27.250>
Call-ID: c40acbe1-37ec0016-57515da2-200a6715@192.168.20.68
Max-Forwards: 70
Date: Sun, 23 Mar 2014 09:38:56 GMT
CSeq: 118 REGISTER
User-Agent: Cisco-CP9951/9.2.1
Contact: <sip:3BDA758-1176@192.168.20.68:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-c40acbe137ec>";+u.sip!devicename.ccm.cisco.com="SEPC40ACBE137EC";+u.sip!model.ccm.cisco.com="537"
Supported: replaces,join,sdp-anat,norefersub,extended-refer,X-cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-5.1.0,X-cisco-xsi-8.0.1
Content-Length: 0
Reason: SIP;cause=200;text="cisco-alarm:24 Name=SEPC40ACBE137EC ActiveLoad=sip9951.9-2-2SR1-9.loads InactiveLoad= Last=phone-reg-rej"
Expires: 3600
3. When i check the configuration file , the load defined is as follows:
#more flash:/its/SEPC40ACBE137EC.cnf.xml | i load
<loadInformation>sip9951.9-0-1SR1</loadInformation>
4. Output from Flash:
CME#sh flash | i 9951
     10728 Mar 22 2014 18:11:58 +03:00 dkern9951.100609R2-9-0-1SR1.sebn
      1474604 Mar 22 2014 18:12:20 +03:00 kern9951.9-0-1SR1.sebn
    27423488 Mar 22 2014 18:13:06 +03:00 rootfs9951.9-0-1SR1.sebn
       143448 Mar 22 2014 18:13:34 +03:00 sboot9951.100609R2-9-0-1SR1.sebn
     1278 Mar 22 2014 18:13:54 +03:00 sip9951.9-0-1SR1.loads
        67000 Mar 22 2014 18:14:26 +03:00 skern9951.022809R2-9-0-1SR1.sebn
5. TFTP Settings:
 tftp-server flash:dkern9951.100609R2-9-0-1SR1.sebn
tftp-server flash:kern9951.9-0-1SR1.sebn
tftp-server flash:rootfs9951.9-0-1SR1.sebn
tftp-server flash:sboot9951.100609R2-9-0-1SR1.sebn
tftp-server flash:sip9951.9-0-1SR1.loads
tftp-server flash:skern9951.022809R2-9-0-1SR1.sebn
6. Voice Register global Settings:
voice register global
 mode cme
 source-address 172.29.27.250 port 5060
 max-dn 35
 max-pool 20
 load 9971 sip9971.9-3-2SR1-1
 load 9951 sip9951.9-0-1SR1
 load 8961 sip8961.9-3-2SR1-1
 timezone 31
 date-format D/M/Y
 mwi reg-e164
 voicemail 8999
 tftp-path flash:
 file text
 create profile sync 0001830533202149
 camera
 video
1 REPLY
Hi Sayeed, Can you please
Hi Sayeed,
Can you please send accross SIP messages when phone is trying to register with CME ?
Manish
72
