9951 phones during srst hold and resume failed for pstn calls
ip phone load:
sip9951.9-2-3-27
vg 2951 ios:
Version 15.1(4)M3
hold and resume for local ip phones to ip phones works fine. but calls to pstn mobile hold and resume not working. anyone has similar problem? any idea whats wrong?
config below:
voice register global
timeouts interdigit 4
max-dn 400
max-pool 250
voice register pool  1
id network 10.10.6.0 mask 255.255.255.0
dtmf-relay rtp-nte
codec g711ulaw
voice service voip
ip address trusted list
  ipv4 x.x.x.1
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip refer
redirect ip2ip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
  call preserve
  session transport udp
sip
  bind control source-interface Loopback0
  bind media source-interface Loopback0
  registrar server expires max 120 min 60
interface Loopback244
ip address 10.x.x.1 255.255.255.255
h323-gateway voip bind srcaddr 10.x.x.1
ip phones are not on local lan. they are routed via local ospf network. attached is the phone log.
hi,
add the following...
1. enable
2. configure terminal
3. voice service voip
4. sip
5. session transport tcp
Karthik
was using the command before it works for the first hold and resume but if i hold again i will not able to resume the call again.
575
