9951 POE Requirement
Can anyone tell exactly how much Power required for 9951 Phones with Camera. if you can send any link that would be helpful.
Thank you.
  • IP Telephony
VIP Purple
Hi, You can use 9900 series
You can use 9900 series along with camera with 802.3af  as per the link below link.
https://supportforums.cisco.com/discussion/10808941/poe-class-4-9951-phones
if you refer table 2.1 , it says 802.3at  for external add-on devices.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/9971_9951_8961/8_6/english/admin_guide/9971ena86/9971ins.html
I suggest speaking to Cisco SE.
regds,
aman
 Hi Aman,Thanks for your
Hi Aman,
Thanks for your quick response.
Customer is having hp 29xx series poe+ switches , 9951 phone is booting up but the camera is not working it giving error "UNABLE TO POWER THE ACCESORY" . When i access the hp switch it showing 6.4 watts for 9951 phone. and needs to exactly tell the customer how much power it require to support phone+camera.
VIP Purple
Hi, Datasheet of 9900 says
Datasheet of 9900 says that it is a Class 3/class 4 device .Class 3 device requires  15.4W under 802.3af.
You can give a try with 802.3af.
regds
aman
Hall of Fame Super Gold
You'll need to force the HP
You'll need to force the HP switch to push 20.0w PoE to the port.
Make sure the HP switch still has ample power left or has excess power to push 20.0w.
60
