01-05-2012 01:34 PM - edited 03-16-2019 08:50 AM
Can you make a video call between a CP-9951 video phone and a CUVA endpoint.
Thanks in advance.
01-05-2012 03:56 PM
I dont see why not.
Chris
01-05-2012 05:03 PM
It should work as long as you're running the latest version of video advantage
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
01-17-2012 01:52 AM
Using CME in C2911-CME-SRST/K9,
I understand you can have video conference calls between multiple 9900 series IP phones. Can you include CUVA endpoints in those conferences using the 9900 series IP phones as the main phones in the conferences?
Look forward to your responce.
01-17-2012 06:55 AM
From CME ADMIN guide:
Video hardware conferencing requires provisioning a heterogeneous DSPFarm video profile with the appropriate video codecs and resolutions.
Once the video profile is available, the SIP line side conference creator can add any type of video-capable IP phone (Cisco Unified 7906, 7911, 7941, 7942, 7945, 7961, 7962, 7965, 7970, 7971, 7975, 8961, 9951, and 9971 IP Phones) to create an ad-hoc or meet-me video conference.
For other participants, Cisco Unified Video Advantage (CUVA) and Cisco Unified 7985 SCCP IP Phones are also supported.
So, looks like CUVA can be a video conference participant.
HTH, please rate all useful posts!
Chris
04-19-2012 11:49 AM
Try the following command, if the problem still exist
ephone N
video
mtp both
After configuring that command in CME 8.6 the problem disappeared immediately
With best regards
