9951 video call from CME 8.6 to CUCM 7.1
Help me please, cant perform voice/video call form CME to CUCM over sip(call as if is established but after two sec of silence  the call is droped)
Logs from CME is attached.
Thanks in advance
voice service voip
no ip address trusted authenticate
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
redirect ip2ip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
  call start slow
sip
  registrar server expires max 600 min 60
  asymmetric payload full
voice class media 1
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice class h323 1
  call start fast
voice register global
mode cme
source-address 192.168.4.192 port 5060
bandwidth video tias-modifier 500000 negotiate end-to-end
max-dn 5
max-pool 5
load 9951 sip9951.9-2-3-27
authenticate register
authenticate realm all
timezone 32
time-format 24
date-format D/M/Y
tftp-path flash:
file text
create profile sync 0004100543778428
network-locale RU
user-locale RU
camera
video
voice register dn  1
number 85709
allow watch
name SMIRNOV D.B.
no-reg
label SMIRNOV D.B.
mwi
voice register pool  1
id mac 64D9.89C3.C654
type 9951
number 1 dn 1
dtmf-relay rtp-nte
username cisco password cisco
codec g711ulaw
no vad
camera
video
dial-peer voice 81 voip
translation-profile outgoing TRANSLATION1
destination-pattern 02481
session protocol sipv2
session target ipv4:172.16.152.254
session transport udp
incoming called-number 85709
voice-class media 1
dtmf-relay rtp-nte
codec g711ulaw
no vad
To be more precise. I perform the call from 9951 sip phone(registred with CME8.6) to 7975 sccp phone (registred with  CUCM7.1.3)
Hall of Fame Super Silver
Check out:
210577: Apr 16 16:21:43.553 MSK: //4551/8F2C479596BB/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 404 Not Found
Reason: Q.850;cause=1
Date: Mon, 16 Apr 2012 12:21:31 GMT
Allow-Events: presence
Content-Length: 0
To: <2481>;tag=001071df-0713-44e5-9ea2-25b6a1e85a80-20338833
404 Not Found typically means the extension is not matched.
Chris
Re: 9951 video call from CME 8.6 to CUCM 7.1
Thank you for your answer,
But 2481 it is number that is assigned to 7975 sccp phone and of course On the Cucm there is not number like 2481@172.16.152.254. I guess CUCM must somehow convert the number to sccp format.
Sure, the @ stuff is not relevant here.
What is the 10.0.139.55 IP address?
Can you post clean "debug ccsip messages"?
Chris
10.0.139.55 is outside int address cme86 ( nat overloaded) and 192.168.4.192 is inside int address cme.
172.16.152.254 is Cucm address.
In the attach, debug ccsip all
Voice call from cme to cucm over sip trunk is now ok(i have to correct CSS on inbound SIP trunk on CUCM), but video is not ok.
Attached new log to original post : dubug ccsip all
Cisco Unified CME 8.6 supports local SIP-video-to-SIP-video calls and SIP-video-to-SCCP-CUVA-video calls on Cisco Unified IP Phones 8961, 9951, and 9971 on the line side. On the trunk side, SIP video call is only supported with SIP trunk. H323 trunk is not supported for video calls on Cisco Unified IP Phones 9951 and 9971.
The media path for SIP video call is flow through and media flow-around is not supported for SIP line in Cisco Unified CME.
Should it work in my configuration?
1025
