05-11-2012 01:27 PM - edited 03-16-2019 11:07 AM
Hi Community
The expansion module CKEM does not initialize on a 9971. The IP Phone is attached to a cube 4.
It's running on CUCM 8.6. Module 1 is enabled for The CKEM 36 buttons. Phone Template is active with Firmware sip9971.9-2-3-27.
The CKEM works fine on a 9951.
Any idea, what I can do?
05-12-2012 10:42 AM
I'd try and check the phone console logs from connecting to the phone's IP address with a browser when the sidecar is connected to the phone to see if there are any errors why it won't power up.
05-17-2012 08:15 AM
Sorry my late answer.
It looks like the phone's connector doesn't work. I just see on the log files, that an extension module is configured but not attached. No power failure.
Anyway I replace that phone.
